I bought a very nice BBK from a guy in germany. (I live in Denmark)
The kit is based on Brembo calibers and these very worn 2-pc. disc/rotor.
What makes it nice is, that the hub is so thick, that spacers are NOT needed in order to clear the calibers. I can therefore make a MOT/TUV without discussion
Trouble is, that I can't find the right disc.........for mounting on the hub.
Have anyone of you guys seen this type of mounting ???????
http://s443.photobucket.com/albums/qq158/chrjen/?action=view¤t=51104521.jpg
What kind of car was it on ? Also a Volvo ?
What car do you need it for ? Volvo 850/S70/V70/C70 ?
Do you also have a picture of the brake calipers
The kit is for a 850.
The calibers are what I believe 993TT.
I have a slight idea - that it is a socalled LOTEC kit - but im not sure at all. Unfortunately LOTEC does not exist anymore...
looks like the discs are also porsche
Why not measure the discs and try to find something that will have the same specifications.
Disc radius
Disc thinkness
Perhaps the are some (part)numbers on the disc somewhere
I have trued everything. Actually i Think the discs are Porsche as well, but Can anyone confirmed this???
Did you already had a look at the ipd website? They offer some porsche kits that would fit our volvo's
That is not the issue. I know All the alternatives, but this is what i want!
Citaat van: chrjen op 19-09-2011 20:20:20
Grrrr yeah understood that already,
but they might have the right discs tot fit your bbk!
Indeed Arjen, just check with IPd and see whether they can provide you with the right Porsche disk.
The original S60R disc appears to fit (think some members have them)... They share the same size (330mmx33mm)
I used to have Mov'it (2pc) brake discs (http://www.movitbrakes.com (http://www.movitbrakes.com))
actually check this topic: http://www.volvo850forum.nl/index.php/topic,20622.0.html (http://www.volvo850forum.nl/index.php/topic,20622.0.html)
You see most members have S60R discs in combination with the 993TT caliper.
And if you are on a budget, try these, Stoptech: http://jdmengineimports.com/brake/Brake-Rotors/Volvo/S60/part-SS-126.39035SL (http://jdmengineimports.com/brake/Brake-Rotors/Volvo/S60/part-SS-126.39035SL)
