http://www.ebay.nl/itm/514-863-0001-Engine-mount-fit-VOLVO-850-06-91-10-97-C-S-V-70-11-96-10-05-/391394762968?hash=item5b20f220d8:g:7RUAAOSwDuJW0i7T (http://www.ebay.nl/itm/514-863-0001-Engine-mount-fit-VOLVO-850-06-91-10-97-C-S-V-70-11-96-10-05-/391394762968?hash=item5b20f220d8:g:7RUAAOSwDuJW0i7T)
Volgens de site van Meyle zou deze moeten passen ...
Citaat van: StefanCJ op 04-03-2016 12:17:03
Volgens VIDA zou deze ( 8631698 ) moeten passen op:
C70 Conv (-05), 1998, B5204T2, AW50-42
C70 Conv (-05), 1998, B5204T2, M56
C70 Conv (-05), 1998, B5204T3, AW50-42
C70 Conv (-05), 1998, B5204T3, M56
C70 Conv (-05), 1998, B5234T3, AW50-42
C70 Conv (-05), 1998, B5234T3, M56
C70 Conv (-05), 1998, B5254T, AW50-42
C70 Conv (-05), 1998, B5254T, M56
C70 Conv (-05), 1999, B5204T3, AW50-42
C70 Conv (-05), 1999, B5204T3, M56
C70 Conv (-05), 1999, B5204T4, AW50-42
C70 Conv (-05), 1999, B5204T4, M56
C70 Conv (-05), 1999, B5234T3, AW50-42
C70 Conv (-05), 1999, B5234T3, M56
C70 Conv (-05), 1999, B5254T, AW50-42
C70 Conv (-05), 1999, B5254T, M56
C70 Conv (-05), 2000, B5204T3, AW50-42
C70 Conv (-05), 2000, B5204T3, M56
C70 Conv (-05), 2000, B5204T4, AW50-42
C70 Conv (-05), 2000, B5204T4, M56
C70 Conv (-05), 2000, B5234T3, AW50-42
C70 Conv (-05), 2000, B5234T3, M56
C70 Conv (-05), 2000, B5244T, AW50-42
C70 Conv (-05), 2000, B5244T, M56
C70 Conv (-05), 2001, B5204T4, AW55-50/51SN
C70 Conv (-05), 2001, B5204T4, M56
C70 Conv (-05), 2001, B5234T3, AW55-50/51SN
C70 Conv (-05), 2001, B5234T3, M56
C70 Conv (-05), 2001, B5244T, AW55-50/51SN
C70 Conv (-05), 2001, B5244T, M56
C70 Conv (-05), 2002, B5204T4, AW55-50/51SN
C70 Conv (-05), 2002, B5204T4, M56
C70 Conv (-05), 2002, B5234T3, AW55-50/51SN
C70 Conv (-05), 2002, B5234T3, M56
C70 Conv (-05), 2002, B5244T, AW55-50/51SN
C70 Conv (-05), 2002, B5244T, M56
C70 Conv (-05), 2003, B5204T4, AW55-50/51SN
C70 Conv (-05), 2003, B5204T4, M56
C70 Conv (-05), 2003, B5234T9, AW55-50/51SN
C70 Conv (-05), 2003, B5234T9, M56
C70 Conv (-05), 2003, B5244T7, AW55-50/51SN
C70 Conv (-05), 2003, B5244T7, M56
C70 Conv (-05), 2004, B5204T4, AW55-50/51SN
C70 Conv (-05), 2004, B5204T4, M56
C70 Conv (-05), 2004, B5234T9, AW55-50/51SN
C70 Conv (-05), 2004, B5234T9, M56
C70 Conv (-05), 2004, B5244T7, AW55-50/51SN
C70 Conv (-05), 2004, B5244T7, M56
C70 Conv (-05), 2005, B5204T4, AW55-50/51SN
C70 Conv (-05), 2005, B5204T4, M56
C70 Conv (-05), 2005, B5234T9, AW55-50/51SN
C70 Conv (-05), 2005, B5234T9, M56
C70 Conv (-05), 2005, B5244T7, AW55-50/51SN
C70 Conv (-05), 2005, B5244T7, M56
C70 Coupe (-02), 1998, B5204T2, AW50-42
C70 Coupe (-02), 1998, B5204T2, M56
C70 Coupe (-02), 1998, B5204T3, AW50-42
C70 Coupe (-02), 1998, B5204T3, M56
C70 Coupe (-02), 1998, B5234T3, AW50-42
C70 Coupe (-02), 1998, B5234T3, M56
C70 Coupe (-02), 1998, B5254T, AW50-42
C70 Coupe (-02), 1998, B5254T, M56
C70 Coupe (-02), 1999, B5204T3, AW50-42
C70 Coupe (-02), 1999, B5204T3, M56
C70 Coupe (-02), 1999, B5204T4, AW50-42
C70 Coupe (-02), 1999, B5204T4, M56
C70 Coupe (-02), 1999, B5234T3, AW50-42
C70 Coupe (-02), 1999, B5234T3, M56
C70 Coupe (-02), 1999, B5254T, AW50-42
C70 Coupe (-02), 1999, B5254T, M56
C70 Coupe (-02), 2000, B5204T3, AW50-42
C70 Coupe (-02), 2000, B5204T3, M56
C70 Coupe (-02), 2000, B5204T4, AW50-42
C70 Coupe (-02), 2000, B5204T4, M56
C70 Coupe (-02), 2000, B5234T3, AW50-42
C70 Coupe (-02), 2000, B5234T3, M56
C70 Coupe (-02), 2000, B5244T, AW50-42
C70 Coupe (-02), 2000, B5244T, M56
C70 Coupe (-02), 2001, B5204T4, AW55-50/51SN
C70 Coupe (-02), 2001, B5204T4, M56
C70 Coupe (-02), 2001, B5234T3, AW55-50/51SN
C70 Coupe (-02), 2001, B5234T3, M56
C70 Coupe (-02), 2001, B5244T, AW55-50/51SN
C70 Coupe (-02), 2001, B5244T, M56
C70 Coupe (-02), 2002, B5204T4, AW55-50/51SN
C70 Coupe (-02), 2002, B5204T4, M56
C70 Coupe (-02), 2002, B5234T3, AW55-50/51SN
C70 Coupe (-02), 2002, B5234T3, M56
C70 Coupe (-02), 2002, B5244T, AW55-50/51SN
C70 Coupe (-02), 2002, B5244T, M56
Bedankt voor de bevestiging. Zojuist besteld.
Maar je krijgt er geen mooi nieuw rubber bij voor onder de versnellingsbak :P
De originele kostte mij 125 euro. Inclusief het mooie nieuwe dopje ;D
(http://myalbum.com/photo/FIGsDNN5Xops/360.jpg)
(http://i.ebayimg.com/00/s/NDAwWDUxMA==/z/7RUAAOSwDuJW0i7T/$_1.JPG)
Edit: Als ik kijk naar beide steunen, lijken bij de originele de bevestigingsgaten precies in het midden van het rubberen blok te zitten, waar die van de Meyle iets naar links lijken te zitten.
Ik ben benieuwd of het toch gewoon past, Steef.
Ik hoop het, zou wel prettig zijn. Dat rubber dopje behandel ik wel met plastidip, is 'ie ook weer zo goed als nieuw 8).
Ligt bovenop het subframe onder de versnellingsbak, Henk.
Ik kwam er pas achter toen ik het onderdeelnummer, dat op het dopje staat, in Vadis opzocht. Stefan en ik vroegen ons al een tijdje af wat het nou voor ding was. En waarom het in het gat van de motorsteun zit??
Nummer 37 op het plaatje.
(http://www.volvopartswebstore.com/images/parts/volvo/fullsize/GR-66753.jpg)
OK maar dan nog snap ik niet wat de steun aan de distri kant van doen heeft met een rubbertje wat onder de bak op het subframe doet. Ik zie het verband niet?
