Project "Auto van de vrouw" (oude Project Sharon thread)
Gestart door Barry_C70, 30-12-2006 20:55:59
Barry_C70
The front was still raised when I measured the rear springs, didn't measure rear panels as i felt the difference in the spring height was already enough of an issue.
Citaat van: Barry_C70 op 29-05-2011 16:23:16
So the car went on the bridge yesterday again. All 4 wheels came off and I found out that the rear-left spring is compressed about 15mm more than the rear-right. Put the wheels back on and measured the spring length again when the car was resting on the wheels and got the same result. Left is lower than right, even though the rings are adjusted evenly in the rear. Might this have something to do with the front right doing all the rubbing?
De achterkant kan inderdaad de voorkant omlaag drukken aan 1 kant. Weet je waarom dit verschil er is? Versleten achterasbus?
Barry_C70
no idea, but I'm not sure that would cause the spring to be more compressed though, maybe less.
The setup is currently like this:
FRONT LEFT: no rubbing                                  FRONT RIGHT rubbing and raised slightly higher than left (1cm)
REAR LEFT: spring 1.5cm shorter than right        REAR RIGHT: 1.5cm longer than left
Barry_C70
I've also been told that the rear left might be shorter due to weight distribution over time (battery, transmission, driver are all on that side)
Barry_C70
Maybe this will make it clearer.
Will adjusting the left rear to be equal with rear right possibly fit rubbing?
Citaat van: Barry_C70 op 08-06-2011 17:03:22
Ik denk dat niemand je hierop antwoord kan geven. Zo verschrikkelijk veel C70's met jouw setup, wielen en symptomen zijn er namelijk niet :eusa_think:
BarryB
Als je nou eens onder de auto kijkt en kijk dan naar je subframe of die nog mooi strak tegen de draagbalken zit, best kans dat je subframe rubbers op zijn.
trial and error i guess  ;D
Je kunt er nog uren hier over filosoferen en allerlei meningen aanhoren, maar op een gegeven moment zul je toch gewoon moeten gaan/laten sleutelen....
michel88
idd
en zou hem la gelijk met ra zetten kwa hoogte ,om te proberen
maar ik denk gewoon als alles dus in orde is hij gewoon omhoog moet :(
Barry_C70
#775
Car's been on the bridge 4 times now with me trying to figure this out, 5 if you include the time I had the camber adjusted hoping that would fix the issue.
Saturday I plan to look again and adjust the rear left coil and check the subframe rubbers to see if they're all in tact.
Thanks for the ideas.
BTW: the rings for the rear springs, are they above or underneath the springs? And is compression and removal of the spring necessary adjust them?
BarryB
Hoe kan je zien dat je rubbers nog goed zijn ?
Sven850
Citaat van: BarryB op 09-06-2011 22:58:24
Scheuren en te grote speling
XC40 T4 Recharge
BarryB
Dat snap ik ook nog wel, maar na tien jaar is de "rek" er ook wel uit. Dan is je subframe gewoon een aantal CM gezakt.
Sven850
Citaat van: BarryB op 10-06-2011 15:27:29
Goede reden om te vervangen dan toch? als hij een paar cm gezakt is :P
XC40 T4 Recharge
