samen vatting service lampje reset
Gestart door BartRas, 24-10-2003 16:37:51
BartRas
Als ik het goed heb kan je de 850 resetten (tot 96) door:
Reset-procedure servicelight:
switch ignition on, open the diagnostic-socket in the motorcompartment, put the plug in opening 7, press
the small button 4 times, wait untill the led lights up steady, press the button once and wait for the led
to glow steady, now press the button 5 times and again wait for the led to show a steady glow, then press
the button one more time and wait for the led to flash rapidly. Now the servicelight on the dash should be
out. It will light up again after 15.000 km. This works only on pre 1996 models.
Voor de V70 vind ik meerder dingen:
-Het kan alleen met OBDII software/kabel
- Het kan door: Reset-procedure servicelight (x70 models):
turn the ignitionkey from "off" to postition II three times while holding the reset-button from your onboard-computer
(if you have one) pushed in. The service-light will now start to flash, now you can release the reset-button.
Next time you start your car the light should be off.
Het kan niet voor modellen 97-98 maar wel voor model 99-2000 door:
Volvo 1999-2000 - S / V / C70 Models Press and Hold odometer reset button Turn ignition switch to "run" position After SRL flashes, release odometer reset button Turn ignition off Turn ignition back on to confirm reset
Zijn die werkende hacks?
there is no substitute for PK's
CiteerVolvo 1999-2000 - S / V / C70 Models Press and Hold odometer reset button Turn ignition switch to "run" position After SRL flashes, release odometer reset button Turn ignition off Turn ignition back on to confirm reset
Dit werkt  :)
