Toch is het zo!
Gestart door SIPS Master, 21-11-2002 21:25:37
Citaat van: FGG op 29-05-2008 09:47:10
Citaat van: )()()sT op 29-05-2008 09:41:37
Ik blijf me verbazen, het is momenteel echt bijna nacht  :o
Altijd al een duister gebied geweest, dat zuiden. :evil:
En ook dát is zo!
Walter
jajaja daarom hebben ze bij jou Starlight, om de duisternis te lijf te gaan
Facta non verba
ex-850club lid/ex-V3C lid
Ion drive
The ion drives of an Imperial-class Star Destroyer.The Ion drive was a type of engine technology used to propel most starships at sublight velocities. Ion engines were fueled by power cells, liquid chemical reactants, onboard generators, or virtually any other device capable of providing sufficient power. The engine utilized internal fusion reactions to produce a stream of highly-charged particles that are forced through the engine's exhaust port at nearly the speed of light.
Ion engines were known to emit mildly radioactive byproducts, requiring onboard technicians to wear protective gear. Because of this radioactivity, it was common protocol for most ships to utilize repulsorlifts for propulsion during atmospheric flight and reserve use of the more powerful ion drives for orbital navigation.
The most noted craft using ion drives were TIE Fighters, who received their name in accordance with the number of ion engines they used: Twin Ion Engine.
KITT
According to series creator Glen A. Larson, as quoted from Knight Rider Legacy, "The car is Knight 2000. KITT is the onboard computer. The car is one, and KITT is the nickname for the computer. I never considered the car was named KITT, just the character inside." The two entities were separated briefly throughout the series.
KITT's Pontiac Trans Am chassis was reinforced with Wilton Knight's revolutionary Molecular Bonded Shell, which was resistant to most known weapons below heavy artillery. The vehicle's drive train consisted of a turbine engine, capable of accelerating to 300 mph; furthermore, the car had numerous other special abilities, the most notable being a frequently used 'Turbo Boost' for jumping over obstacles.
DEURKNOP
Een deurknop, deurkruk of klink zit aan een deur, waarmee deze open en dicht gedaan kan worden. Een deurknop kan niet altijd rondgedraaid worden en dient dan alleen voor het opentrekken en dichtdoen van de deur. In de deurknop kan het slot van de deur opgenomen zijn. Meestal wordt het dagslot echter met een deurkruk bediend, en bevindt het nachtslot zich daaronder. Een klink doet zelf dienst als dagslot.
Tussen een deurkruk en de deur zit ter versiering meestal een krukrozet of een krukschild, ook sluitplaat genoemd.
Met een deurkruk of ronddraaiende deurknop kan de deursluiting opengedraaid worden door de kruk naar beneden te duwen of de knop rond te draaien. Door vervolgens te trekken of te duwen kan de deur open en dicht gedaan worden.
Een deurknop moet voor het draaien stevig vastgepakt worden, wat bij ouderen soms problemen geeft.
De meeste deurkrukken hebben een vierkante as die door de deurstijl gaat en waarop aan beide zijden van de deur de kruk of knop zit. De ene knop is een geheel met de as en de andere knop wordt met een schroef of een conisch toelopend stalen pennetje er op vastgezet. De twee knoppen zijn dan vast met dezelfde as verbonden. In de vierkante as zit een stelbout of op regelmatige afstanden een gaatje voor aanpassing aan de dikte van de deur.
Er zijn echter ook andere constructies mogelijk. Bij sommige toiletdeuren kan de deurkruk aan de binnenzijde omhoog worden gedraaid om de deur af te sluiten. De deurkruk aan de buitenzijde blijft dan horizontaal - de deurkrukken zijn dus niet vast met elkaar verbonden. Een buitendeur heeft vaak alleen een deurkruk aan de binnenkant. Aan de buitenkant moet een sleutel worden gebruikt.
De vaste deurknop kan dicht bij de rand geplaatst zijn of midden op de deur.
Vroeger werd een deurkruk of deurknop vaak van hout gemaakt. Nu zijn de deurkrukken meestal van metaal, zoals messing, koper, aluminium, roestvast staal (inox), chroom of smeedijzer.
Daarnaast moet worden opgemerkt dat de top van Mount Everest niet het verst van de kern van de aarde gelegen punt is. Doordat de aarde aan de polen afgeplat is en aan de evenaar uitdijt, is de straal van de aarde op de evenaar 21 km groter dan aan de polen. De Chimborazo die bijna op de evenaar ligt, neemt daardoor met 6384 km een koppositie in (tegen 6382 km voor de Everest). Desalniettemin is de Everest wel degelijk de hoogste top in termen van zwaartekracht en dus gemiddeld zeeniveau. Wanneer er een aquaduct tussen de top van de Everest en de top van de Chimborazo gebouwd zou worden, zou het water van de Everest naar de Chimborazo stromen en niet andersom.
mikky
Domaso
Een Tupperware party wordt verzorgd door een demonstratrice van Tupperware. Zij geeft uitleg over de producten aan de hand van de catalogus in het huis van een gastvrouw die vriendinnen, familie en/of buren te gast heeft. Afhankelijk van de hoogte van de omzet ontvangt de gastvrouw als beloning gratis producten. Ook eventuele vervolgafspraken die door gasten kunnen worden gemaakt om een party te geven worden beloond met gratis producten. Tegenwoordig kan de gastvrouw ook kiezen voor een zgn. kookstudio i.p.v. de traditionele party. Tijdens deze kookstudio gaan de gasten zelf aan de slag met de Tupperware producten.
Naast de Tupperware party wordt voor de verkoop ook gebruik gemaakt van kiosks in winkelcentra. In de Verenigde Staten en Canada kunnen producten ook online worden gekocht.
FREE LIMBABWE
  Limburg vrie!
Domaso
Citaat van: Claudia op 29-05-2008 22:20:51
Het Intratuin Borderplan
Verschillende planten combineren tot een gevarieerde border vol kleuren en geuren is nu makkelijker dan ooit! Intratuin heeft namelijk de kennis van groenspecialisten en stylisten gecombineerd in een uniek plan. Met het Intratuin Borderplan kies je de border die je het mooiste vindt. Op basis van een boodschappenlijst kun je deze border heel makkelijk samenstellen voor je eigen tuin. Elke border heeft zijn eigen kenmerken en zorgt voor voldoende variatie in hoogte en bloei.
En dat is écht zo....
Nu nog zo'n concept voor Ikea.
FREE LIMBABWE
  Limburg vrie!
Ronbroek
Het krediet op uw intratuin-creditcard is opgewaardeerd naar 10.000 Euro
