Humor!
Gestart door SIPS Master, 12-08-2006 19:39:57
Stond gisterenmorgen op,.......moe.......lui........nergens zin in..........ja, om op de bank te hangen,..........gewoon niks doen de hele dag, daar had ik zin in !
Dus ik naar de dokter,.........
Blijk ik Surinaamse griep te hebben.........  :-\
Citaat van: Laserblue op 27-11-2009 17:05:54
Dat heb je dan al een tijdje.  ::)
Citaat van: FGG op 27-11-2009 18:17:38
born and raised on the sofa, used to spent most of my days relaxing........ :eusa_whistle:
Wibren
Tower: "Delta 351, you have traffic at 10 o'clock, 6 miles!"
Delta 351: "Give us another hint! We have digital watches!"
Tower: "TWA 2341, for noise abatement turn right 45 Degrees."
TWA 2341: "Center, we are at 35,000 feet. How much noise can we make up here?"
Tower: "Sir, have you ever heard the noise a 747 makes when it hits a 727?"
A student became lost during a solo cross-country flight. While attempting to locate the aircraft on radar, ATC asked, "What was your last known position?"
Student: "When I was number one for takeoff."
A DC-10 had come in a little hot and thus had an exceedingly long roll out after touching down.
San Jose Tower Noted: "American 751, make a hard right turn at the end of the runway, if you are able. If you are not able, take the Guadeloupe exit off Highway 101, make a right at the lights and return to the airport."
A Pan Am 727 flight, waiting for start clearance in Munich , overheard the following:
Lufthansa (in German): "Ground, what is our start clearance time?"
Ground (in English): "If you want an answer you must speak in English."
Lufthansa (in English): "I am a German, flying a German airplane, in Germany . Why must I speak English?"
Unknown voice from another plane (in a beautiful British accent): "Because you lost the bloody war!"
Tower: "Eastern 702, cleared for takeoff, contact Departure on frequency 124.7"
Eastern 702: "Tower, Eastern 702 switching to Departure. By the way, after we lifted off we saw some kind of dead animal on the far end of the runway."
Tower: "Continental 635, cleared for takeoff behind Eastern 702, contact Departure on frequency 124.7. Did you copy that report from Eastern 702?"
Continental 635: "Continental 635, cleared for takeoff, roger; and yes, we copied Eastern... We've already notified our caterers."
One day the pilot of a Cherokee 180 was told by the tower to hold short of the active runway while a DC-8 landed... The DC-8 landed, rolled out, turned around, and taxied back past the Cherokee. Some quick-witted comedian in the DC-8 crew got on the radio and said,
"What a cute little plane. Did you make it all by yourself?"
The Cherokee pilot, not about to let the insult go by, came back with a real zinger:
"I made it out of DC-8 parts. Another landing like yours and I'll have enough parts for another one."
The German air controllers at Frankfurt Airport are renowned as a short-tempered lot. They not only expect one to know one's gate parking location, but how to get there without any assistance from them. So it was with some amusement that we (a Pan Am 747) listened to the following exchange between Frankfurt ground control and a British Airways 747, call sign Speedbird 206.
Speedbird 206: " Frankfurt , Speedbird 206! Clear of active runway."
Ground: "Speedbird 206. Taxi to gate Alpha One-Seven."
The BA 747 pulled onto the main taxiway and slowed to a stop.
Ground: "Speedbird, do you not know where you are going?"
Speedbird 206: "Stand by, Ground, I'm looking up our gate location now."
Ground (with quite arrogant impatience): "Speedbird 206, have you not been to Frankfurt before?"
Speedbird 206 (coolly): "Yes, twice in 1944, but it was dark, -- And I didn't land..."
While taxiing at London 'S Airport, the crew of a US Air flight departing for Ft. Lauderdale made a wrong turn and came nose to nose with a United 727.
An irate female ground controller lashed out at the US Air crew, screaming:
"US Air 2771, where the hell are you going? I told you to turn right onto Charlie taxiway! You turned right on Delta! Stop right there. I know it's difficult for you to tell the difference between C and D, but get it right!"
Continuing her rage to the embarrassed crew, she was now shouting hysterically:
"God! Now you've screwed everything up! It'll take forever to sort this out! You stay right there and don't move till I tell you to! You can expect progressive taxi instructions in about half an hour, and I want you to go exactly where I tell you, when I tell you, and how I tell you! You got that, US Air 2771?"
"Yes, ma'am," the humbled crew responded.
Naturally, the ground control communications frequency fell terribly silent after the verbal bashing of US Air 2771. Nobody wanted to chance engaging the irate ground controller in her current state of mind. Tension in every cockpit out around Gatwick was definitely running high.
Just then an unknown pilot broke the silence and keyed his microphone, asking:
"Wasn't I married to you once?"
Wibren
After every flight, Qantas pilots fill out a form called a gripe sheet, which conveys to the mechanics problems encountered with the aircraft during the flight that need repair or correction. The mechanics read and correct the problem, and then respond in writing on the lower half of the form what remedial action was taken, and the pilot reviews the gripe sheets before the next flight.
Never let it be said that ground crews and engineers lack a sense of humour.
Here are some actual logged maintenance complaints and problems as submitted by Qantas pilots and the solution recorded by maintenance engineers.
(P = The problem logged by the pilot.)
(S = The solution and action taken by the mechanics.)
P: Left inside main tire almost needs replacement.
S: Almost replaced left inside main tire.
P: Test flight OK, except auto-land very rough.
S: Auto-land not installed on this aircraft.
P: Something loose in cockpit.
S: Something tightened in cockpit.
P: Dead bugs on windshield.
S: Live bugs on back-order.
P: Autopilot in altitude-hold mode produces a 200 feet per minute descent.
S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear.
S: Evidence removed.
P: DME volume unbelievably loud.
S: DME volume set to more believable level.
P: Friction locks cause throttle levers to stick.
S: That's what they're there for.
P: IFF inoperative.
S: IFF always inoperative in OFF mode.
P: Suspected crack in windshield.
S: Suspect you're right.
P: Number 3 engine missing.
S: Engine found on right wing after brief search.
P: Aircraft handles funny.
S: Aircraft warned to straighten up, fly right, and be serious.
P: Target radar hums.
S: Reprogrammed target radar with lyrics.
P: Mouse in cockpit.
S: Cat installed.
P: Noise coming from under instrument panel. Sounds like a midget pounding on
something with a hammer.
S: Took hammer away from midget.
Reitse
lig al vanaf gisteren avond in bed.....................................   :eusa_shifty:
belde vanochtend met de baas ..........................................
Wist wel dat hij me niet goed zou verstaan........................
Vertelde hem dat ik met een mexicaanse griet in bed lag :eusa_dance:
Ben
A Kansas farm wife called the local phone company to report her telephone failed to ring when her friends called - and that on the few occasions, when it did ring, her dog always moaned right before the phone rang.
The telephone repairman proceeded to the scene, curious to see this psychic dog or senile lady. He climbed a telephone pole, hooked in his test set, and dialed the subscriber's house...
The phone didn't ring right away, but then the dog moaned and the telephone began to ring...
Climbing down from the pole, the telephone repairman found:
1. The dog was tied to the telephone system's ground wire with a steel chain and collar.
2. The wire connection to the ground rod was loose.
3. The dog was receiving 90 volts of signaling current when the number was called.
4. After a couple of jolts, the dog would start moaning and then urinate.
5. The wet ground would complete the circuit, thus causing the phone to ring.
Which demonstrates that some problems CAN, in fact, be fixed by pissing and moaning.
rogerV701998
(Dagblad De Limburger 5 december 2009)
FelixB
855R & C70 T5 cabrio automaat
FrankM
HET IS WINTER DUS.....
Norman en zijn blonde vrouw luisteren tijdens het ontbijt naar de   radio en horen de regionale nieuwslezer zeggen : "Er wordt 8 tot 10 cm sneeuw verwacht vandaag.
Wilt u uw auto aan de kant van de straat parkeren met de oneven nummers ,  dan kan de sneeuwploeg er ongestoord langs rijden."
De vrouw van Norman gaat naar buiten en zet haar auto op de aangegeven plaats.
Een week later, weer tijdens het ontbijt, meldt de nieuwslezer op de radio "We verwachtenvandaag 10 tot 12 cm sneeuw.
Wilt u uw auto aan de kant van de straat parkeren met de even nummers zodat de sneeuwploeg er ongestoord door kan ?"
De vrouw van Norman gaat naar buiten en plaatst haar auto weer op de aangegeven plaats
Weer een week later, weer tijdens het ontbijt zegt de nieuwslezer
"Wij verwachten 12 tot 14 centimeter sneeuw. Wilt u uw auto . . .
Op dat moment valt de stroom uit...................
De vrouw van Norman is in alle staten en met een bezorgd gezicht vraagt ze     aan haar man Norman
"Schat, nu weet ik niet wat doen. Aan welke kant van de straat moet ik nu de     auto  parkeren zodat de sneeuwploeg er ongestoord door kan???"
Waarop Norman, met de liefde en begrip in zijn stem
zoals alle mannen die met een blonde vrouw getrouwd zijn, antwoordt :
"Waarom laat je hem deze keer niet gewoon in de garage staan ??
t5karel
http://www.shithappens.nl/
Beetje confronterend,maar wel met een knipoog ;)
Uiteindelijk heb ik mij bijna doodgelachen ;D ;D
Citaat van: t5karel op 07-12-2009 22:17:09
;D ;D ;D ;D
Blotebillengezicht!  :eusa_dance:
