Project "Auto van de vrouw" (oude Project Sharon thread)
Gestart door Barry_C70, 30-12-2006 20:55:59
Barry_C70
that's a secondary air filter for in case my car had a secondary air system, usually found on cars where snow could block the primary air inlet and suffocate the engine (like Sweden) but I couldn't find it on my car even though I had a SAS inlet :P
BartusKN
haha ik ga binnenkort denk ik ook eens wat verdiepen in een open luchtfilter maar die stekkers weet me er geen raad mee.
maar al met al je heb er een hele mooie auto van gemaakt! zou zo willen ruilen :P
Barry_C70
Further development: I've noticed that upon high reving, that the engine vibrates a LOT, I think its about time to install the new poly' engine mount and transmission assembly and see the difference. I think any kind of increased vibration is worth is compared to the amount the engine displaces upon higher revs.
Barry_C70
okay then, continued to make upgrades to the car.
I attempted to install the engine mount and transmission assembly but HOLY CRAP those things are tight, no way I could get the stock ones off, so I'll leave and try those for another day.
Spacers were easy enough though, 25mm on the rear, 15mm on the front.
Before the new spacers with 15mm on the rear:
After:
Spacers zien er goed uit Barry! Merk je verschil met rijden? (bv bij sturen of inveren?)
Lag jou auto trouwens niet een stuk lager? Of leek dat maar zo door de zomer-velgen? Of moet / wil je dat nog gaan doen?
Hebbie ook een foto van de zijkant?  (haaks erop dus)
850 T5 Freak
Ziet er nu al dik uit Barry  8) nu nog die Ruige Imi's eronder  ;D
Barry_C70
Citaat van: viking_in_shorts op 08-03-2008 18:29:49
The car was off the ground for quite some time so I don't think it had settled completely yet. But I think the perception of the smaller wheels makes it look like that too. I do plan on installing coilovers at somepoint, but I'll see how things look when the 19"s go back on with spacers, maybe lowering isn't necessary to much anymore when the wheels stick out that much and fill the wheel well.
I'll take side pics tomorrow
BartusKN
ziet er zeker mooi uit.  alleen nu gaat zeker je bumper ontzettend vies worden dan niet sneller.
850 T5 Freak
dat worden ze zoiezo al  ;D toch maar een keer een groupsbuy mudflaps gaan organiseren!! ofniet Barry?  ;D
Barry_C70
#189
Citaat van: 850 T5 Freak op 08-03-2008 23:13:04
Sure, you start! ;D
You think mudflaps would look good? I've seen pics of a silver C70 with painted rear mudflaps, doesn't look good at all :eusa_snooty:
BartusKN
last pic looks photoshopped cos the shadow on the right-rear flap the bottum of it its way to bright. think its a faky :D
Citaat van: Barry_C70 op 09-03-2008 01:13:45
mee eens
yuck :-X
moderators
Citaat van: BartusKN op 09-03-2008 02:47:18
In het Nederlands a.u.b!
Deelnemen aan dit forum? Hou je dan aan de forumregels
Wil je je niet aan de forumregels houden? Blijf dan weg van dit forum
Heb dit draadje ook ooit gevolgd: is wel degelijk echt. Ikzelf vind de kont altijd een beetje puntig, dus recht van achter is dit best wel mooi. Vanuit elke andere willekeurige hoek echter ....
Barry_C70
upper poly engine mount from IPD installed, getting the oem one out was a real bi@tch! Getting the new one in took a few minutes.
First impressions: engine noise is a bit louder, definitely more roffel! ;D and power feels more solid and I can definitely feel more power being sent to the wheels than being lost in engine shudder. A positive upgrade then! Recommended to anyone who's thinking about one!
I dunno what everyone was talking about with cabin vibrations, I didn't feel anything more or less concerning that. Might be a powerflex attribute, not so with this IPD one!
Also started polishing up the IC pipe, not done yet, but had to put it back in cuz I need to drive around:
