ThoR5: V70R en V60 T5 Polestar
Gestart door Chris, 22-07-2007 19:11:21
Ff een lijstje met foutcode's opgezocht voor de mensen zonder Vida. Zoals je ziet kan er nog al wat fout gaan met een N. ;D
ABS-0010 Left front wheel sensor Signal missing. Intermittent fault
ABS-0010 Left front wheel sensor Signal missing. Permanent fault
ABS-0010 Left front wheel sensor. Signal missing. Intermittent fault
ABS-0010 Left front wheel sensor. Signal missing. Permanent fault
ABS-0011 Left front wheel sensor Faulty signal
ABS-0011 Left front wheel sensor. Faulty signal
ABS-0012 Left front wheel sensor Faulty signal
ABS-0020 Right front wheel sensor. Signal missing. Intermittent fault
ABS-0020 Right front wheel sensor. Signal missing. Permanent fault
ABS-0021 Right front wheel sensor. Faulty signal
ABS-0022 Front right wheel sensor. Faulty signal
ABS-0022 Right front wheel sensor. Faulty signal
ABS-0030 Left rear wheel sensor Signal missing. Intermittent fault
ABS-0030 Left rear wheel sensor Signal missing. Permanent fault
ABS-0030 Left rear wheel sensor. Signal missing. Intermittent fault
ABS-0030 Left rear wheel sensor. Signal missing. Permanent fault
ABS-0031 Left rear wheel sensor. Faulty signal
ABS-0032 Left rear wheel sensor. Faulty signal
ABS-0040 Right rear wheel sensor. Signal missing. Intermittent fault
ABS-0040 Right rear wheel sensor. Signal missing. Permanent fault
ABS-0041 Right rear wheel sensor. Faulty signal
ABS-0042 Right rear wheel sensor. Faulty signal
ABS-0064 Stop lamp switch. Faulty signal
ABS-0065 Stop (brake) lamp switch. Faulty signal. Permanent fault
ABS-0065 Stop (brake) light switch. Faulty signal. Intermittent fault
ABS-0065 Stop (brake) light switch. Faulty signal. Permanent fault
ABS-0066 Front brake discs. Temperature too high
ABS-0070 Pump motor. Faulty signal. Intermittent fault
ABS-0070 Pump motor. Faulty signal. Permanent fault
ABS-0072 Control module. Internal fault. Intermittent fault
ABS-0072 Control module. Internal fault. Permanent fault
ABS-0074 Battery voltage. Voltage too low. Intermittent fault
ABS-0074 Battery voltage. Voltage too low. Permanent fault
ABS-0075 Control module. Internal fault. Intermittent fault
ABS-0075 Control module. Internal fault. Permanent fault
ABS-0076 Control module. Faulty configuration
ABS-0077 Battery voltage. Voltage too high. Intermittent fault
ABS-0077 Battery voltage. Voltage too high. Permanent fault
ABS-0080 Control module. Faulty signal. Intermittent fault
ABS-0080 Control module. Faulty signal. Permanent fault
ABS-0090 Control module. Internal fault. Intermittent fault
ABS-0090 Control module. Internal fault. Permanent fault
ABS-0091 Control module communication. Control module communication
ABS-0092 Control module communication. Control module communication
ABS-0093 Control module communication. Control module communication
ABS-0094 Control module communication. Control module communication
ABS-0095 Control module communication. Control module communication. Intermittent fault
ABS-0095 Control module communication. Control module communication. Permanent fault
ABS-0097 Control module. Excessive configuration time
ABS-00A0 Yaw-velocity sensor 1. Signal faulty. Intermittent fault
ABS-00A0 Yaw-velocity sensor 1. Signal faulty. Permanent fault
ABS-00A1 Yaw rate sensor 1 & 2. Signal outside its permitted range
ABS-00A2 Side acceleration sensor. Signal faulty. Intermittent fault
ABS-00A2 Side acceleration sensor. Signal faulty. Permanent fault
ABS-00A3 Lateral acceleration sensor Signal outside its permitted range
ABS-00A3 Side acceleration sensor. Unreasonable signal
ABS-00A4 Brake pressure sensor 1. Signal faulty. Intermittent fault
ABS-00A4 Brake pressure sensor 1. Signal faulty. Permanent fault
ABS-00A5 Brake pressure sensor 2. Signal faulty. Intermittent fault
ABS-00A5 Brake pressure sensor 2. Signal faulty. Permanent fault
ABS-00A6 Brake pressure sensor 1 & 2. Signal outside its permitted range
ABS-00A7 Power supply sensor. Signal faulty. Intermittent fault
ABS-00A7 Sensor power supply. Signal faulty. Permanent fault
ABS-00B0 Brake amplifier pre-pressure valve Signal faulty. Intermittent fault
ABS-00B0 Brake amplifier pre-pressure valve Signal faulty. Permanent fault
ABS-00B0 Power brake booster pressure build-up valve. Faulty signal. Permanent fault
ABS-00B1 Pedal pressure sensor. Signal faulty. Intermittent fault
ABS-00B1 Pedal pressure sensor. Signal faulty. Permanent fault
ABS-00B2 Yaw-velocity sensor 2. Signal faulty. Intermittent fault
ABS-00B2 Yaw-velocity sensor 2. Signal faulty. Permanent fault
ABS-00B3 Communication control unit SAS signal. Unreasonable signal
ABS-00B4 Communication control unit SAS control unit not initiated
ABS-00B5 Communication control unit SAS signal quality
ABS-00B6 Communication control unit Internal fault in CAN or SAS
ABS-00B7 Communication control unit Incorrect wheel alignment or steering angle
ABS-00C0 Stabilising function. AYC stabilisation takes too long
ABS-00C1 Stabilising function. Incorrect wheel alignment or steering wheel positioning
ABS-00C2 Reversing signal. Unreasonable signal
ABS-00C3 Reversing signal. No signal
ABS-00C4 Control unit. Internal fault
ABS-00C7 DSTC Factory test. The testing cycle is not approved
ADM-0001 Additive dosing module (ADM). Internal fault
ADM-0002 Level sensor, additive. Faulty signal
ADM-0003 Level sensor, additive. Faulty signal
ADM-0004 Tank level, additive. Fault-tracing information
ADM-0005 Tank level, additive. Fault-tracing information
ADM-0006 Pump, additive. Signal missing
ADM-0007 Pump, additive. Signal too low
ADM-0008 Pump, additive. Signal too high
ADM-0009 Control module. Incorrect configuration
ADM-000A Vehicle speed. Faulty signal
ADM-000B Fuel level. Faulty signal
ADM-E000 Control module. Faulty communication
ADM-E003 Configuration fault
ADM-E010 Power supply control module. Signal too low
AEM-1A01 Power supply. Signal too low. Intermittent fault
AEM-1A01 Power supply. Signal too low. Permanent fault
AEM-1D01 Control module. Internal fault
AEM-1D01 Control module. Internal fault. Intermittent fault
AEM-1D01 Control module. Internal fault. Permanent fault
AEM-1D02 Control module, software. Internal fault
AEM-1D02 Control module, software. Internal fault. Intermittent fault
AEM-1D02 Control module, software. Internal fault. Permanent fault
AEM-1D03 Control module not fully programmed. Internal fault
AEM-1D03 Control module not fully programmed. Internal fault. Intermittent fault
AEM-1D03 Control module not fully programmed. Internal fault. Permanent fault
AEM-1D07 Control module. Internal fault
AEM-1D07 Control module. Internal fault. Intermittent fault
AEM-1D07 Control module. Internal fault. Permanent fault
AEM-1D08 Control module. Internal fault
AEM-1D08 Control module. Internal fault. Intermittent fault
AEM-1D08 Control module. Internal fault. Permanent fault
AEM-1D0A Control module. Internal fault
AEM-1D0A Control module. Internal fault. Intermittent fault
AEM-1D0A Control module. Internal fault. Permanent fault
AEM-4F60 Back-up (reversing) warning system. Signal too low. Intermittent fault
AEM-4F60 Back-up (reversing) warning system. Signal too low. Permanent fault
AEM-4F61 Back-up (reversing) warning system. Signal too high. Intermittent fault
AEM-4F61 Back-up (reversing) warning system. Signal too high. Permanent fault
AEM-4F62 Back-up (reversing) warning system, buzzer. Signal too low. Intermittent fault
AEM-4F62 Back-up (reversing) warning system, buzzer. Signal too low. Permanent fault
AEM-4F63 Back-up (reversing) warning system, buzzer. Signal too high. Intermittent fault
AEM-4F63 Back-up (reversing) warning system, buzzer. Signal too high. Permanent fault
AEM-5F10 Relay, engine block heater. Signal too low
AEM-5F10 Relay, engine block heater. Signal too low. Intermittent fault
AEM-5F10 Relay, engine block heater. Signal too low. Permanent fault
AEM-5F11 Relay, engine block heater. Signal too high / Signal missing
AEM-5F11 Relay, engine block heater. Signal too high or Signal missing. Intermittent fault
AEM-5F11 Relay, engine block heater. Signal too high or Signal missing. Permanent fault
AEM-5F20 Remote start. Signal too low. Intermittent fault
AEM-5F20 Remote start. Signal too low. Permanent fault
AEM-5F22 Remote start. Signal too low. Intermittent fault
AEM-5F22 Remote start. Signal too low. Permanent fault
AEM-5F23 Remote start. Signal too high. Intermittent fault
AEM-5F23 Remote start. Signal too high. Permanent fault
AEM-6C50 Alarm output P0. Signal too low or signal missing
AEM-6C50 Alarm output P0. Signal too low or signal missing. Intermittent fault
AEM-6C50 Alarm output P0. Signal too low or signal missing. Permanent fault
AEM-6C51 Alarm output P0. Signal too high
AEM-6C51 Alarm output P0. Signal too high. Intermittent fault
AEM-6C51 Alarm output P0. Signal too high. Permanent fault
AEM-6C52 Alarm output P1. Signal too low or signal missing
AEM-6C52 Alarm output P1. Signal too low or signal missing. Intermittent fault
AEM-6C52 Alarm output P1. Signal too low or signal missing. Permanent fault
AEM-6C53 Alarm output P1. Signal too high
AEM-6C53 Alarm output P1. Signal too high. Intermittent fault
AEM-6C53 Alarm output P1. Signal too high. Permanent fault
AEM-6C54 Alarm output S0. Signal too low or signal missing
AEM-6C54 Alarm output S0. Signal too low or signal missing. Intermittent fault
AEM-6C54 Alarm output S0. Signal too low or signal missing. Permanent fault
AEM-6C55 Alarm output S0. Signal too high
AEM-6C55 Alarm output S0. Signal too high. Intermittent fault
AEM-6C55 Alarm output S0. Signal too high. Permanent fault
AEM-6C56 Alarm output S1. Signal too low
AEM-6C56 Alarm output S1. Signal too low. Intermittent fault
AEM-6C56 Alarm output S1. Signal too low. Permanent fault
AEM-6C57 Alarm output S1. Signal too high / Signal missing
AEM-6C57 Alarm output S1. Signal too high or Signal missing. Intermittent fault
AEM-6C57 Alarm output S1. Signal too high or Signal missing. Permanent fault
AEM-7A10 Carphone mute signal. Signal too low. Intermittent fault
AEM-7A10 Carphone mute signal. Signal too low. Permanent fault
AEM-7A11 Carphone mute signal. Signal too high or Signal missing. Intermittent fault
AEM-7A11 Carphone mute signal. Signal too high or Signal missing. Permanent fault
AEM-7A12 Rheostat signal. Signal too low / high or signal missing. Intermittent fault
AEM-7A12 Rheostat signal. Signal too low / high or signal missing. Permanent fault
AEM-7A14 Speed signal. Signal too low / high or signal missing. Intermittent fault
AEM-7A14 Speed signal. Signal too low / high or signal missing. Permanent fault
AEM-7A16 Antenna amplifier. Signal too low. Intermittent fault
AEM-7A16 Antenna amplifier. Signal too low. Permanent fault
AEM-7A17 Antenna amplifier. Signal too high or Signal missing. Intermittent fault
AEM-7A17 Antenna amplifier. Signal too high or Signal missing. Permanent fault
AEM-E001 Control module communication. Faulty communication
AEM-E003 Configuration fault. Faulty configuration
AEM-E003 Control module communication Faulty communication
AEM-E010 Power supply. Signal too low
AFM-0001 Antenna AM/FM. Signal missing
AFM-0002 Antenna AM/FM. Signal too high
AFM-0003 Antenna AM/FM. Configuration fault
ATM-0001 Antenna module (ATM). Non matching
ATM-0002 TMC receiver. Configuration fault
ATM-0003 TMC receiver. Signal missing
ATM-0004 GPS unit. Configuration fault
ATM-0005 GPS unit. Signal missing
ATM-0006 GPS unit. Internal fault
ATM-0007 GPS unit. Internal fault
AUD-0001 Control module. Internal fault
AUD-0002 Loudspeaker left front. Signal missing
AUD-0003 Loudspeaker right front. Signal missing
AUD-0004 Loudspeaker left rear. Signal missing
AUD-0005 Loudspeaker right rear. Signal missing
AUD-0006 Loudspeaker left front. Signal too high / low
AUD-0007 Center loudspeaker. Signal too high / low
AUD-0008 Loudspeaker right front. Signal too high / low
AUD-0009 Loudspeaker left rear. Signal too high / low
AUD-000A Loudspeaker right rear. Signal too high / low
AUD-000B Loudspeakers front. Signal too high / low
AUD-000C Loudspeaker rear. Signal too high / low
AUD-000D Control module. Over heated
AUD-000E Microphone terminal. Signal missing
AUD-000F Microphone terminal. Signal too high
AUD-0010 Microphone terminal. Signal too low
AUD-0011 Buttons headset 1. Signal missing
AUD-0012 Buttons headset 1. Signal too low
AUD-0013 Buttons headset 2. Signal too low
AUD-0014 Buttons headset 2. Signal missing
AUD-0015 Buttons headset 3. Signal missing
AUD-0016 Buttons headset 3. Signal too low
AUD-0017 Buttons headset 4. Signal missing
AUD-0018 Buttons headset 4. Signal too low
AUD-0019 Headset panel left. Activated too long
AUD-001A Headset panel right. Activated too long
AUM-1000 Memory control Audio HU1205. Faulty signal
AUM-2000 CD-servo Audio HU1205. Faulty signal
AUM-2100 CD unit Audio HU1205. Faulty signal
AUM-3000 GPS receiver Audio HU1205. Faulty signal
AUM-3100 GPS antenna Audio HU1205. Faulty signal
AUM-4001 Antenna amplifier 1. Signal too low. Intermittent fault
AUM-4001 Antenna amplifier 1. Signal too low. Permanent fault
AUM-4002 Amplifier, main antenna. Signal too high. Intermittent fault
AUM-4002 Amplifier, main antenna. Signal too high. Permanent fault
AUM-40FF Amplifier, main antenna. Signal missing. Intermittent fault
AUM-40FF Amplifier, main antenna. Signal missing. Permanent fault
AUM-41FF Amplifier, sub-antenna. Signal missing. Intermittent fault
AUM-41FF Amplifier, sub-antenna. Signal missing. Permanent fault
AUM-4201 Single CD player. Focus fault. Intermittent fault
AUM-4201 Single CD player. Focus fault. Permanent fault
AUM-4201 Single CD player. Focusing fault. Intermittent fault
AUM-4201 Single CD player. Focussing fault. Permanent fault
AUM-4203 Single CD player. MD/CD servo fault. Intermittent fault
AUM-4203 Single CD player. MD/CD servo fault. Permanent fault
AUM-42F1 Single CD player. Fault in load / eject. Intermittent fault
AUM-42F1 Single CD player. Fault in load / eject. Permanent fault
AUM-42F1 Single CD player. Fault in load/eject. Intermittent fault
AUM-42F1 Single CD player. Fault in load/eject. Permanent fault
AUM-42F3 Single CD player. Pick-up fault. Intermittent fault
AUM-42F3 Single CD player. Pick-up fault. Permanent fault
AUM-42FF Single CD player. Not connected or communication problems. Intermittent fault
AUM-42FF Single CD player. Not connected or communication problems. Permanent fault
AUM-4301 MiniDisc player. Focus fault. Permanent fault
AUM-4301 MiniDisc player. Focusing fault. Intermittent fault
AUM-4301 MiniDisc player. Focusing fault. Permanent fault
AUM-4303 MiniDisc player
AUM-4303 MiniDisc player. MD/CD servo fault. Intermittent fault
AUM-4303 MiniDisc player. MD/CD servo fault. Permanent fault
AUM-43F1 MiniDisc player. Fault in load / eject. Permanent fault
AUM-43F1 MiniDisc player. Fault in load/eject. Intermittent fault
AUM-43F1 MiniDisc player. Fault in load/eject. Permanent fault
AUM-43F3 MiniDisc player. Pick-up fault. Intermittent fault
AUM-43F3 MiniDisc player. Pick-up fault. Permanent fault
AUM-43FF MiniDisc player. Not connected or communication problems. Intermittent fault
AUM-43FF MiniDisc player. Not connected or communication problems. Permanent fault
AUM-4401 4 disc CD changer. Focus fault. Intermittent fault
AUM-4401 4 disc CD changer. Focus fault. Permanent fault
AUM-4401 4 disc CD changer. Focusing fault. Intermittent fault
AUM-4401 4 disc CD changer. Focusing fault. Permanent fault
AUM-4403 4 disc CD changer. MD/CD servo fault. Intermittent fault
AUM-4403 4 disc CD changer. MD/CD servo fault. Permanent fault
AUM-44F1 4 disc CD changer. Fault in load / eject + E58. Intermittent fault
AUM-44F1 4 disc CD changer. Fault in load / eject + E58. Permanent fault
AUM-44F1 4 disc CD changer. Fault in load/eject + E58. Intermittent fault
AUM-44F1 4 disc CD changer. Fault in load/eject + E58. Permanent fault
AUM-44F2 4 disc CD changer. Fault in disc selection. Intermittent fault
AUM-44F2 4 disc CD changer. Fault in disc selection. Permanent fault
AUM-44F3 4 disc CD changer. Pick-up fault. Intermittent fault
AUM-44F3 4 disc CD changer. Pick-up fault. Permanent fault
AUM-44FF 4 disc CD changer. Not connected or communication problems. Intermittent fault
AUM-44FF 4 disc CD changer. Not connected or communication problems. Permanent fault
AUM-4501 Cassette deck. Fault in load / eject. Permanent fault
AUM-4501 Cassette deck. Fault in load/eject. Intermittent fault
AUM-4501 Cassette deck. Fault in load/eject. Permanent fault
AUM-45FF Cassette deck. Not connected or communication problems. Intermittent fault
AUM-45FF Cassette deck. Not connected or communication problems. Permanent fault
AUM-4601 10 disc CD changer. Focus fault. Permanent fault
AUM-4601 10 disc CD changer. Focusing fault. Intermittent fault
AUM-4601 10 disc CD changer. Focusing fault. Permanent fault
AUM-4603 10 disc CD changer. CD servo fault. Intermittent fault
AUM-4603 10 disc CD changer. CD servo fault. Permanent fault
AUM-46F1 10 disc CD changer. Fault in load / eject. Permanent fault
AUM-46F1 10 disc CD changer. Fault in load/eject. Intermittent fault
AUM-46F1 10 disc CD changer. Fault in load/eject. Permanent fault
AUM-46F2 10 disc CD changer. Fault in disc selection. Intermittent fault
AUM-46F2 10 disc CD changer. Fault in disc selection. Permanent fault
AUM-46F3 10 disc CD changer. Pick-up fault. Intermittent fault
AUM-46F3 10 disc CD changer. Pick-up fault. Permanent fault
AUM-46FE 10 disc CD changer. Faulty installation. Intermittent fault
AUM-46FE 10 disc CD changer. Faulty installation. Permanent fault
AUM-46FF 10 disc CD changer. Not connected or communication problems. Intermittent fault
AUM-46FF 10 disc CD changer. Not connected or communication problems. Permanent fault
AUM-47FE Amplifier. Faulty installation. Intermittent fault
AUM-47FE Amplifier. Faulty installation. Permanent fault
AUM-47FF Amplifier. Not connected or communication problems. Intermittent fault
AUM-47FF Amplifier. Not connected or communication problems. Permanent fault
AUM-48FD Control module. Faulty frequency setting. Intermittent fault
AUM-48FD Control module. Faulty frequency setting. Permanent fault
AUM-49FD Control module. Faulty installation. Intermittent fault
AUM-49FD Control module. Faulty installation. Permanent fault
AUM-4BFF Control module. Internal program fault. Intermittent fault
AUM-4BFF Control module. Internal program fault. Permanent fault
AUM-6000 Audio unit Audio HU1205. Faulty signal
AUM-E001 Communication with control module. Internal fault
AUM-E001 Control module communication. Faulty communication
AUM-E003 Communication with control module. Internal fault. Intermittent fault
AUM-E003 Communication with control module. Internal fault. Permanent fault
AUM-E003 Configuration fault. Faulty configuration
BCM-0010 Left front wheel sensor. Signal missing
BCM-0010 Wheel sensor left front. Faulty signal
BCM-0011 Left front wheel sensor. Faulty signal
BCM-0011 Wheel sensor left front. Faulty signal
BCM-0012 Left front wheel sensor. Faulty signal
BCM-0012 Wheel sensor left front. Mechanical fault
BCM-0020 Right front wheel sensor. Signal missing
BCM-0020 Wheel sensor right front. Faulty signal
BCM-0021 Right front wheel sensor. Faulty signal
BCM-0021 Wheel sensor right front. Faulty signal
BCM-0022 Right front wheel sensor. Faulty signal
BCM-0022 Wheel sensor right front. Mechanical fault
BCM-0030 Left rear wheel sensor. Signal missing
BCM-0030 Wheel sensor left rear. Faulty signal
BCM-0031 Left rear wheel sensor. Faulty signal
BCM-0031 Wheel sensor left rear. Faulty signal
BCM-0032 Left rear wheel sensor. Faulty signal
BCM-0032 Wheel sensor left rear. Mechanical fault
BCM-0040 Right rear wheel sensor. Signal missing
BCM-0040 Wheel sensor right rear. Faulty signal
BCM-0041 Right rear wheel sensor. Faulty signal
BCM-0041 Wheel sensor right rear. Faulty signal
BCM-0042 Right rear wheel sensor. Faulty signal
BCM-0042 Wheel sensor right rear. Mechanical fault
BCM-0050 Control module. Faulty signal
BCM-0052 Control module. Internal fault
BCM-0057 Power supply. Voltage too low
BCM-0058 Power supply. Voltage too high
BCM-0061 Brake discs. Temperature too high
BCM-0065 Stop lamp switch. Faulty signal
BCM-0065 Stop lamp switch/pedal position sensor. Signal outside its permitted range
BCM-0068 Sensor power supply. Faulty signal
BCM-0070 Power supply for the pump motor. Faulty signal
BCM-0071 Pump motor. Signal missing
BCM-0072 Pump motor. Mechanical fault
BCM-0074 Hydraulic valves. Faulty signal
BCM-0076 Control module. Faulty configuration
BCM-0080 Lateral accelerometer. Incorrect offset value
BCM-0081 Accelerometer. Incorrect offset value
BCM-0082 Yaw rate sensor. Incorrect offset value
BCM-0083 Angle of lean sensor. Incorrect offset value
BCM-0090 Lateral accelerometer. Faulty signal
BCM-0091 Accelerometer. Faulty signal
BCM-0092 Yaw rate sensor. Faulty signal
BCM-0093 Angle of lean sensor. Faulty signal
BCM-0094 Communication between control modules. Communication problems with Active on Demand Coupling
BCM-0094 Communication between control modules. Communication problems with the differential electronic module (DEM)
BCM-0095 Communication between control modules. Communication problems with Active on Demand Coupling
BCM-0095 Communication between control modules. Communication problems with the differential electronic module (DEM)
BCM-0097 Communication between control modules. Communication problems with the central electronic module (CEM)
BCM-0100 Communication between control modules. Communication problems with the engine control module (ECM)
BCM-0101 Communication between control modules. Communication problems with the engine control module (ECM)
BCM-0103 Pedal position sensor. Faulty signal
BCM-0105 Steering wheel, wheel alignment. Signal outside its permitted range
BCM-0106 Steering wheel or wheel alignment. Incorrect steering wheel or wheel alignment
BCM-0106 Steering wheel, wheel alignment. Incorrect steering wheel or wheel alignment
BCM-0108 Communication between control modules. Communication problems with the steering wheel module (SWM), control module not initiated
BCM-0108 Communication between control modules. Communication with the steering angle sensor. Control module not initiated
BCM-0109 Communication between control modules. Communication with the steering angle sensor. Internal fault
BCM-0109 Communication between control modules. Steering wheel module (SWM), internal fault
BCM-0111 Communication between control modules. AYC stability control active for too long
BCM-0111 Communication between control modules. Check of the steering angle sensor tolerances has not been run
BCM-0112 Active yaw control sensor. Sensor not calibrated
BCM-0112 Body sensor cluster stability sensor (BSC). Sensor not calibrated
BCM-0113 Back-up (reversing) signal. Signal missing
BCM-0114 Communication with the active yaw control sensor. Signal missing
BCM-0114 Communication with the body sensor cluster stability sensor (BSC). Signal missing
BCM-0115 Communication between control modules. Communication with the steering angle sensor. Signal missing
BCM-0115 Communication between control modules. Communication with the steering wheel module (SWM), signal missing
BCM-0116 Communication with the active yaw control sensor. Communication problems
BCM-0116 Communication with the body sensor cluster stability sensor (BSC). Communication problems
BCM-0117 Communication with the active yaw control sensor. An incorrect active yaw control sensor had been installed
BCM-0117 Communication with the body sensor cluster stability sensor (BSC). Incorrect body sensor cluster stability sensor (BSC) installe
BCM-0118 Power supply for the active yaw control sensor. Voltage too high
BCM-0118 Power supply for the body sensor cluster stability sensor (BSC). Voltage too high
BCM-0119 Power supply for the active yaw control sensor. Voltage too low
BCM-0119 Power supply for the body sensor cluster stability sensor (BSC). Voltage too low
BCM-0121 Yaw rate sensor. Signal outside its permitted range
BCM-0123 Active yaw control sensor. Internal fault
BCM-0123 Body sensor cluster stability sensor (BSC). Internal fault
BCM-0125 Lateral accelerometer. Signal outside its permitted range
BCM-0127 Angle of lean sensor. Signal outside its permitted range
BCM-0129 Accelerometer. Signal outside its permitted range
BCM-0130 Brake pressure sensor 1. Signal too low
BCM-0130 Brake pressure sensor. Signal missing
BCM-0131 Brake pressure sensor. Faulty signal
BCM-0132 Brake pressure sensor. Incorrect temperature
BCM-0133 Brake pressure sensor 2. Signal too low
BCM-0133 Brake pressure sensor. Faulty signal
BCM-0134 Brake pressure sensor. Incorrect offset value
BCM-0135 Brake pressure sensor. Signal outside its permitted range
BCM-0136 Brake pressure sensor 1 and 2. Signal outside its permitted range
BCM-0138 Power supply for the active yaw control sensor. Faulty voltage
BCM-0138 Power supply for the body sensor cluster stability sensor (BSC). Faulty voltage
BCM-0139 Pressure build-up valve, power brake booster. Signal outside its permitted range
BCM-0140 Pedal pressure sensor. Signal outside its permitted range
BCM-0145 Stability control. Stability control has been active for too long
BCM-0145 Stability control. Too long stability control
BCM-0146 Factory test, dynamic stability and traction control (DSTC). Test cycle not approved
BCM-0147 Pedal position sensor. Signal outside its permitted range
CCM-0001 Blower fan motor. Signal too low
CCM-0001 Configuration fault. Non-approved value
CCM-0002 Blower fan motor. Signal too high
CCM-0002 Evaporator temperature sensor. Signal too high / Signal missing
CCM-0002 Evaporator temperature sensor. Signal too high or signal missing
CCM-0003 Blower fan motor passenger compartment temperature sensor. Faulty signal
CCM-0003 Evaporator temperature sensor. Signal too low
CCM-0004 Compressor. Faulty signal
CCM-0004 Passenger compartment temperature sensor. Signal too high / Signal missing
CCM-0004 Passenger compartment temperature sensor. Signal too high or signal missing
CCM-0005 Evaporator temperature sensor. Signal too high
CCM-0005 Passenger compartment temperature sensor. Signal too high / Signal missing
CCM-0005 Passenger compartment temperature sensor. Signal too low
CCM-0006 Blower fan motor passenger compartment temperature sensor. Signal too high / Signal missing
CCM-0006 Blower fan motor passenger compartment temperature sensor. Signal too high or signal missing
CCM-0006 Evaporator temperature sensor. Signal too low
CCM-0006 Temperature damper motor position sensor. Signal too low. Intermittent fault
CCM-0006 Temperature damper motor position sensor. Signal too low. Permanent fault
CCM-0007 Passenger compartment temperature sensor. Faulty signal
CCM-0007 Temperature damper motor position sensor. Signal too high. Intermittent fault
CCM-0007 Temperature damper motor position sensor. Signal too high. Permanent fault
CCM-0008 Blower fan motor passenger compartment temperature sensor. Signal too low
CCM-0008 Sun sensor. Signal too high
CCM-0009 Blower fan motor passenger compartment temperature sensor. Blocked
CCM-0009 Sun sensor. Signal too low
CCM-000A Air distribution damper motor position sensor Signal too low. Intermittent fault
CCM-000A Air distribution damper motor position sensor Signal too low. Permanent fault
CCM-000A Nightfall sensor. Signal faulty. Intermittent fault
CCM-000A Nightfall sensor. Signal faulty. Permanent fault
CCM-000B Air distribution damper motor position sensor. Signal too high. Intermittent fault
CCM-000B Air distribution damper motor position sensor. Signal too high. Permanent fault
CCM-000B Left temperature damper motor. Signal too low
CCM-000C Right temperature damper motor. Signal too low
CCM-000D Recirculation damper motor. Signal too low
CCM-000E Damper motor, floor / ventilation. Signal too low
CCM-000F Damper motor defroster. Signal too low
CCM-0010 Air distribution damper motor. Signal too low
CCM-0010 Control module. Internal fault
CCM-0011 Control module. Internal fault
CCM-0011 Left temperature damper motor. Signal too high
CCM-0012 Right temperature damper motor. Signal too high
CCM-0012 Temperature damper motor. Blocked
CCM-0013 Air distribution damper motor. Blocked
CCM-0013 Recirculation damper motor. Signal too high. Permanent fault
CCM-0014 Damper motor, floor and ventilation. Signal too high
CCM-0015 Damper motor defroster. Signal too high
CCM-0016 Air distribution damper motor. Signal too high
CCM-0017 Damper motor direction control. Signal too low
CCM-0017 Direction regulator damper motor. Signal too low. Intermittent fault
CCM-0017 Direction regulator damper motor. Signal too low. Permanent fault
CCM-0018 Damper motor direction control. Signal too high
CCM-0018 Direction regulator damper motor. Signal too high. Intermittent fault
CCM-0018 Direction regulator damper motor. Signal too high. Permanent fault
CCM-0019 Function button. Activated for long time. Intermittent fault
CCM-0019 Function button. Activated for long time. Permanent fault
CCM-0019 Function button. Activated too long
CCM-001A Blower fan knob. Faulty signal
CCM-001B Blower fan motor. Signal too low
CCM-001B Lower switch. ID missing
CCM-001C Lower switch. Faulty ID
CCM-001D Left temperature knob. Faulty signal
CCM-001E Right Temperature knob. Faulty signal
CCM-001F Air quality sensor. Signal too high
CCM-001F Blower fan motor. Signal too high
CCM-0020 Air quality sensor. Signal too low
CCM-0020 Blower fan power unit. Signal too high
CCM-0020 Function button. Activated too long
CCM-0021 Air quality sensor. Internal fault
CCM-0021 Blower fan power unit. Signal too low
CCM-0022 Air quality sensor. Faulty ID
CCM-0030 Left heater pad. Faulty signal
CCM-0031 Sensor left-hand seat heater. Faulty signal
CCM-0032 Left-hand seat heater. Internal fault
CCM-0033 Left-hand seat heater. Internal fault
CCM-0034 Right heater pad. Faulty signal
CCM-0035 Sensor right-hand seat heater. Faulty signal
CCM-0036 Right-hand seat heater. Internal fault
CCM-0037 Right-hand seat heater. Internal fault
CCM-0040 Air quality sensor. Internal fault
CCM-0045 Blower fan relay. Signal too high
CCM-0046 Blower fan relay. Signal too low
CCM-0050 Blower fan knob. Faulty signal
CCM-0051 Temperature control left. Faulty signal
CCM-0052 Left-hand seat heater. Faulty signal. Intermittent fault
CCM-0052 Left-hand seat heater. Faulty signal. Permanent fault
CCM-0052 Temperature control right. Faulty signal
CCM-0053 Air distribution control. Faulty signal
CCM-0053 Right-hand seat heater. Faulty signal. Intermittent fault
CCM-0053 Right-hand seat heater. Faulty signal. Permanent fault
CCM-0056 Communication with the left-hand seat heater. Faulty signal. Intermittent fault
CCM-0056 Communication with the left-hand seat heater. Faulty signal. Permanent fault
CCM-0057 Communication with the right-hand seat heater. Faulty signal. Intermittent fault
CCM-0057 Communication with the right-hand seat heater. Faulty signal. Permanent fault
CCM-0058 Communication with the left-hand seat heater. Signal too high. Intermittent fault
CCM-0058 Communication with the left-hand seat heater. Signal too high. Permanent fault
CCM-0059 Communication with the right-hand seat heater. Signal too high. Intermittent fault
CCM-0059 Communication with the right-hand seat heater. Signal too high. Permanent fault
CCM-0060 Damper motor defroster. Faulty signal
CCM-0060 Damper motor defroster. Internal fault
CCM-0061 Rear demist, heated door mirrors. Signal too high
CEM-1010 Control module memory fault. Internal fault
CEM-1011 (A) Control module memory fault. Internal fault
CEM-1011 (B) Control module memory fault. Internal fault
CEM-1012 (A) Control module memory fault. Internal fault
CEM-1012 (B) Control module memory fault. Internal fault
CEM-1A03 S-Power supply. Signal too low. Intermittent fault
CEM-1A03 S-Power supply. Signal too low. Permanent fault
CEM-1A04 X-Power supply. Signal too low
CEM-1A04 X-Power supply. Signal too low. Intermittent fault
CEM-1A04 X-Power supply. Signal too low. Permanent fault
CEM-1A05 30 Power supply. Signal too low. Intermittent fault
CEM-1A05 30 Power supply. Signal too low. Permanent fault
CEM-1A05 X-Power supply. Signal too high. Intermittent fault
CEM-1A05 X-Power supply. Signal too high. Permanent fault
CEM-1A06 15-Power supply. Signal too low
CEM-1A06 15-Power supply. Signal too low. Intermittent fault
CEM-1A06 15-Power supply. Signal too low. Permanent fault
CEM-1A07 15-Power supply. Signal too high
CEM-1A07 15-Power supply. Signal too high. Intermittent fault
CEM-1A07 15-Power supply. Signal too high. Permanent fault
CEM-1A08 50-Power supply. No signal. Intermittent fault
CEM-1A08 50-Power supply. No signal. Permanent fault
CEM-1A08 50-Power supply. Signal missing
CEM-1A08 50-Power supply. Signal missing. Intermittent fault
CEM-1A08 50-Power supply. Signal missing. Permanent fault
CEM-1A09 50-Power supply. Signal too high
CEM-1A09 50-Power supply. Signal too high. Intermittent fault
CEM-1A09 50-Power supply. Signal too high. Permanent fault
CEM-1A21 Engine control module (ECM). Signal too low
CEM-1A21 Increased power supply relay. Signal too high. Intermittent fault
CEM-1A21 Increased power supply relay. Signal too high. Permanent fault
CEM-1A22 Engine control module (ECM). Signal too high
CEM-1A23 Increased power supply relay. No signal. Intermittent fault
CEM-1A23 Increased power supply relay. No signal. Permanent fault
CEM-1A24 Relay Ext X2-Power supply. Signal too high. Intermittent fault
CEM-1A24 Relay Ext X2-Power supply. Signal too high. Permanent fault
CEM-1A25 Relay Ext X2-Power supply. Signal too low. Intermittent fault
CEM-1A25 Relay Ext X2-Power supply. Signal too low. Permanent fault
CEM-1A26 Relay, 15i power supply. Signal too high
CEM-1A27 Relay, 15i power supply. Signal too low
CEM-1A40 50-power supply. Activated too long
CEM-1A41 (A) Ignition switch. Faulty signal
CEM-1A41 (B) Real time clock. Faulty signal
CEM-1A41 Real time clock. Faulty signal
CEM-1A41 Real time clock. Internal fault. Intermittent fault
CEM-1A41 Real time clock. Internal fault. Permanent fault
CEM-1A42 Real time clock. Faulty signal
CEM-1A42 Real time clock. Internal fault. Intermittent fault
CEM-1A42 Real time clock. Internal fault. Permanent fault
CEM-1A51 Communication with the supplemental restraint system module (SRS). Signal missing
CEM-1A52 Communication with the driver door module (DDM). Signal missing
CEM-1A53 Communication with the passenger door module (PDM). Signal missing
CEM-1A54 Communication with the power seat module (PSM). Signal missing
CEM-1A55 Communication with the climate control module (CCM). Signal missing
CEM-1A56 Communication with the driver information module (DIM). Signal missing
CEM-1A57 Communication with the RTI module. Signal missing
CEM-1A58 Communication with the carphone module (PHM). Signal missing
CEM-1A58 Communication with the phone module (PHM). Signal missing
CEM-1A59 Communication with the audio module (AUM). Signal missing
CEM-1A5A Communication with the rear electronic module (REM). Signal missing
CEM-1A5B Communication with the steering wheel module (SWM). Signal missing
CEM-1A5C Communication with the upper electronic module (UEM). Signal missing
CEM-1A5D Communication with the electronic throttle module (ETM). Signal missing
CEM-1A5E Communication with the steering wheel angle sensor module (SAS). Signal missing
CEM-1A5F Communication with ABS control unit. No signal. Intermittent fault
CEM-1A5F Communication with ABS control unit. No signal. Permanent fault
CEM-1A5F Communication with the ABS control module. Signal missing. Intermittent fault
CEM-1A5F Communication with the ABS control module. Signal missing. Permanent fault
CEM-1A5F Communication with the brake control module (BCM). Signal missing
CEM-1A5F Communication with the brake control module. Signal missing
CEM-1A61 Communication with the transmission control module (TCM). Signal missing
CEM-1A62 Communication with the engine control module (ECM). Signal missing
CEM-1A63 Communication with the accessory electronic module (AEM). Signal missing
CEM-1A63 Communication with the accessory electronic module. Signal missing
CEM-1A64 Communication with the differential electronic module (DEM). Signal missing
CEM-1A65 Communication with the suspension module (SUM). Signal missing
CEM-1A66 Communication with the infotainment control module (ICM). Signal missing
CEM-1C01 L signal. Signal too high. Intermittent fault
CEM-1C01 L signal. Signal too high. Permanent fault
CEM-1C02 L signal. Signal too low. Intermittent fault
CEM-1C02 L signal. Signal too low. Permanent fault
CEM-1C04 30 Power supply. Signal too high. Intermittent fault
CEM-1C04 30 Power supply. Signal too high. Permanent fault
CEM-1C04 30-power supply. Signal too high
CEM-1C05 30-Power supply. Signal too low
CEM-1C06 Alternator control module (ACM). Electrical fault
CEM-1C07 Alternator control module (ACM). Over heated
CEM-1C08 Alternator control module (ACM). Mechanical fault
CEM-1C0A Alternator control module (ACM). Voltage too high
CEM-1C21 Relay, infotainment. Signal too high
CEM-1C22 Relay, infotainment. Signal too low or signal missing
CEM-1D01 Control module memory fault. Internal fault
CEM-1D01 Control module. Internal fault
CEM-1D01 Control module. Internal fault. Intermittent fault
CEM-1D01 Control module. Internal fault. Permanent fault
CEM-1D02 Control module, software. Internal fault. Intermittent fault
CEM-1D02 Control module, software. Internal fault. Permanent fault
CEM-1D02 Control module. Internal fault
CEM-1D03 Control module not fully programmed. Internal fault
CEM-1D03 Control module not fully programmed. Internal fault. Intermittent fault
CPM-0018 Glow plugs. Signal too high
CPM-0102 Glow plugs. Signal too low
CPM-0204 Glow plugs. Signal missing
CPM-0318 Fuel pump. Signal too high
CPM-0402 Fuel pump. Signal too low
CPM-0504 Fuel pump. Signal missing
CPM-1001 Combustion fan. Signal too high
CPM-1128 Combustion fan. Signal too low
CPM-1204 Combustion fan. Signal missing
CPM-1308 Combustion fan. Faulty function
CPM-1418 Water pump. Signal too high
CPM-1502 Water pump. Signal too low
CPM-1604 Water pump. Signal missing
CPM-2308 Control module. Internal fault
CPM-3002 Engine coolant temperature (ECT) sensor. Signal too low
CPM-3141 Engine coolant temperature (ECT) sensor. Signal too high / Signal missing
CPM-3202 Overheat protection thermostat. Signal too low
CPM-3341 Overheat protection thermostat. Signal too high / Signal missing
CPM-3402 Flame sensor. Signal too low
CPM-3541 Flame sensor. Signal too high / Signal missing
CPM-3601 Control module. Supply voltage too high
CPM-3702 Control module. Supply voltage too low
CPM-4001 Engine coolant heater. Activated too long
CPM-4101 Engine coolant heater. Too many unsuccessful attempts
CPM-4208 Engine coolant heater. Extinguished flame
CPM-4308 Engine coolant heater. Extinguished flame
CPM-4501 Combustion fan. Activated too long
CPM-5001 Control module. Over heated
CPM-5101 Control module. Over heated
CPM-5201 Control module. Over heated
CPM-5301 Control module. Over heated
CPM-5401 Control module. Internal fault
CPM-5601 Control module. Internal fault
CPM-5701 Control module. Collision signal received
CPM-6008 Control module. Internal fault
CPM-6108 Control module. Internal fault
CPM-6208 Control module. Internal fault
CPM-6301 Control module. Internal fault
CPM-6408 Control module. Internal fault
CPM-6508 Control module. Internal fault
CPM-8602 Control module. Internal fault
CPM-8704 Control module. Internal fault
CPM-E001 Control module communication. Faulty communication
CPM-E003 Configuration fault. Faulty configuration
CPM-E010 Control module. Supply voltage too low
DDM-0001 Power window lift motor M+ or M-. Signal too high
DDM-0002 Central locking button. Stuck in the active position
DDM-0003 Central locking button, unlocking. Stuck in the active position
DDM-0005 Power window lift motor M+ or M-. Signal missing
DDM-0005 Power window lift motor M+ or M-. Signal too low or signal missing
DDM-0005 Window-lifting motor M+. Signal missing
DDM-0006 Power window up relay. Signal too high
DDM-0007 Power window up relay. Faulty signal
DDM-0009 Window-lifting motor M-. Signal missing
DDM-000A Window lift down relay. Signal too high
DDM-000B Power window down relay. Faulty signal
DDM-000C Power window mechanism. Internal fault
DDM-000D Central locking motor M1 or M3. Signal too high
DDM-000D Central locking motor M1, M2 or M3. Signal too high
DDM-0010 Central locking motor M1. Signal too low
DDM-0010 Central locking motor M1. Signal too low or signal missing
DDM-0010 Control panel. Open-circuit
DDM-0011 Central locking relay RL2_RD2. Signal too high
DDM-0011 Control panel. Open-circuit
DDM-0012 Central locking relay RL2_RD2. Signal too low
DDM-0013 Central locking motor M3. Signal too low
DDM-0013 Central locking motor M3. Signal too low or signal missing
DDM-0013 Control, passenger window. Stuck in the active position
DDM-0014 Central locking relay RL2_RD4. Signal too high
DDM-0014 Control, left rear side window. Stuck in the active position
DDM-0015 Central locking relay RL2_RD4. Signal too low
DDM-0015 Control, right rear side window. Stuck in the active position
DDM-0016 Central locking motor M2. Signal too low
DDM-0016 central locking motor M2. Signal too low or signal missing
DDM-0016 Child-proof lock. Stuck in the active position
DDM-0017 Central locking relay RL3. Signal too high
DDM-0018 Central locking relay RL3. Signal too low
DDM-0018 Control, rear side window. Faulty signal
DDM-0019 Control, rear side window. Stuck in the active position
DDM-0019 Lock, driver's door. Signal too low
DDM-001A Lock, driver's door. Signal too low
DDM-001B Lock, driver's door. Signal too low
DDM-001D Central locking button. Internal fault
DDM-0020 Control, door mirror. Stuck in the active position
DDM-0020 Power window mechanism Hall sensor 1. Faulty signal
DDM-0020 Window lift Hall sensor 1. Signal faulty
DDM-0021 Control, door mirror. Stuck in the active position
DDM-0021 Power window mechanism Hall sensor 2. Faulty signal
DDM-0021 Window lift Hall sensor 2. Signal faulty
DDM-0022 Control, door mirror selector. Stuck in the active position
DDM-0022 Power window mechanism Hall sensor 1 and 2. Faulty signal
DDM-0022 Window lift Hall sensors 1 and 2. Signal faulty
DDM-0023 Control, door mirror selector. Stuck in the active position
DDM-0023 Door mirror motor MX+. Signal too high
DDM-0023 Mirror motor MX+. Signal too high
DDM-0024 Door mirror motor MX+. Signal too low
DDM-0024 Mirror motor MX+. Signal too low
DDM-0025 Door mirror motor. Disconnected
DDM-0026 Door mirror motor MY+. Signal too high
DDM-0026 Mirror motor MY+. Signal too high
DDM-0027 Door mirror motor MY+. Signal too low
DDM-0027 Mirror motor MY+. Signal too low
DDM-0028 Door mirror motor MF+. Signal too high
DDM-0028 Mirror motor MF+. Signal too high
DDM-0029 Door mirror motor MF+. Signal too low
DDM-0029 Mirror motor MF+. Signal too low
DDM-002A Mirror motor MC. Signal too high
DDM-002A Window motor MC. Signal too high
DDM-002B Mirror motor MC. Signal too low
DDM-002B Window motor MC. Signal too low
DDM-002C Door mirror heater. Signal too high
DDM-002C Mirror heater. Signal too high
DDM-002D Door mirror heater. Signal too low
DDM-002D Mirror heater. Signal too low
DDM-002E Door mirror heater. Signal too high
DDM-002E Mirror heater. Signal too high
DDM-002F Door mirror motor. Overheating or current too high
DDM-002F Window motor. Signal too high
DDM-0030 Door mirror potentiometer. Faulty signal
DDM-0030 Door mirror potentiometer. Faulty signal. Intermittent fault
DDM-0030 Door mirror potentiometer. Faulty signal. Permanent fault
DDM-0031 Door mirror potentiometer. Signal too low
DDM-0031 Door mirror potentiometer. Signal too low. Intermittent fault
DDM-0031 Door mirror potentiometer. Signal too low. Permanent fault
DDM-0032 Door mirror potentiometer. Faulty signal
DDM-0032 Door mirror potentiometer. Faulty signal. Intermittent fault
DDM-0032 Door mirror potentiometer. Faulty signal. Permanent fault
DDM-0033 Door mirror potentiometer. Signal too low
DDM-0033 Door mirror potentiometer. Signal too low. Intermittent fault
DDM-0033 Door mirror potentiometer. Signal too low. Permanent fault
DDM-0034 Driver-side window control. Signal faulty
DDM-0035 Control, passenger window. Faulty signal
DDM-0035 Passenger-side window control. Signal faulty
DDM-0036 Control, left rear side window. Faulty signal
DDM-0037 Control, right rear side window. Faulty signal
DDM-0038 Control, door mirror. Faulty signal Davew
DDM-0039 Child-proof lock. Stuck in the active position
DDM-003C Control, passenger window. Faulty signal
DDM-003C Passenger-side window control. Signal too high
DDM-003D Control, left rear side window. Faulty signal
DDM-003D Rear left side-window control. Signal too high
DDM-003E Control, right rear side window. Faulty signal
DDM-003E Rear right side-window control. Signal too high
DDM-003F Control, door mirror. Signal too high
DDM-003F Rear-view mirror control. Signal too high
DEM-0001 Temperature sensor. Faulty signal
DEM-0002 Pressure sensor. Faulty signal
DEM-0003 System voltage. Faulty voltage
DEM-0005 Control valve. Faulty signal
DEM-0005 Control valve. Internal fault
DEM-0007 Hydraulic pressure. Incorrect value
DEM-0008 Control module calibration fault. Internal fault
DEM-0008 Control module, calibration fault. Internal fault
DEM-0008 Control module. Internal fault
DEM-0009 Control module Analog/Digital converter. Internal fault
DEM-0009 Control module. Internal fault
DEM-000A Power supply. Faulty voltage
DEM-000A Power supply. Incorrect value
DEM-000C Control module. Faulty hardware
DEM-E000 Control module communication. Faulty communication
DEM-E003 Configuration fault. Faulty configuration
DIM-0001 Driving distance. Incorrect value
DIM-0001 Mileage. Manipulated
DIM-0001 Vehicle speed signal. Faulty signal
DIM-0002 ABS warning lamp. Faulty circuit
DIM-0002 ABS-lamp. Faulty circuit
DIM-0002 Fuel level sensor. Faulty signal. Intermittent fault
DIM-0002 Fuel level sensor. Faulty signal. Permanent fault
DIM-0003 Fuel level sensor. Faulty signal. Intermittent fault
DIM-0003 Fuel level sensor. Faulty signal. Permanent fault
DIM-0003 SRS warning lamp. Faulty circuit
DIM-0003 SRS-lamp. Faulty circuit
DIM-0004 Fuel level sensor. Signal missing. Intermittent fault
DIM-0004 Fuel level sensor. Signal missing. Permanent fault
DIM-0005 Engine coolant temperature (ECT) sensor signal. Faulty signal. Intermittent fault
DIM-0005 Engine coolant temperature (ECT) sensor signal. Faulty signal. Permanent fault
DIM-0005 Red general warning lamp. Faulty circuit
DIM-0005 Red warning lamp. Faulty circuit
DIM-0006 12-pulse vehicle speed signal. Signal too high. Intermittent fault
DIM-0006 12-pulse vehicle speed signal. Signal too high. Permanent fault
DIM-0006 Information lamp. Faulty circuit
DIM-0006 Orange general warning lamp. Faulty circuit
DIM-0007 12-pulse vehicle speed signal. Signal too low. Intermittent fault
DIM-0007 12-pulse vehicle speed signal. Signal too low. Permanent fault
DIM-0007 Global parameter. Internal fault
DIM-0007 Global parameter. Internal fault.
DIM-0008 Fuel level sensor. Jammed
DIM-0009 Fuel ejector. Internal fault
DIM-000A D+ signal. Signal too low. Intermittent fault
DIM-000A D+ signal. Signal too low. Permanent fault
DIM-000B Outside temperature sensor. Faulty signal. Intermittent fault
DIM-000B Outside temperature sensor. Faulty signal. Permanent fault
DIM-000C Control module. Internal fault
DIM-000C Control unit. Internal fault. Intermittent fault
DIM-000C Control unit. Internal fault. Permanent fault
DIM-000D Communication engine control module (ECM). Faulty signal. Intermittent fault
DIM-000D Communication engine control module (ECM). Faulty signal. Permanent fault
DIM-000E Control module. Internal fault. Intermittent fault
DIM-000E Control module. Internal fault. Permanent fault
DIM-DF13 CAN bus H-signal. Signal too high. Intermittent fault
DIM-DF13 CAN bus H-signal. Signal too high. Permanent fault
DIM-DF14 CAN bus L signal. Signal too low. Intermittent fault
DIM-DF14 CAN bus L signal. Signal too low. Permanent fault
DIM-DF15 CAN bus H signal. Signal too low. Intermittent fault
DIM-DF15 CAN bus H signal. Signal too low. Permanent fault
DIM-DF16 CAN bus L signal. Signal too high. Intermittent fault
DIM-DF16 CAN bus L signal. Signal too high. Permanent fault
DIM-E000 Communication control module. Internal fault
DIM-E001 Control module communication. Faulty communication
DIM-E003 Configuration fault. Faulty configuration
DIM-E003 Software fault. Faulty communication
ECM-0000 Engine speed (RPM) sensor. Faulty signal. Intermittent fault
ECM-0000 Impulse sensor. Faulty signal, Intermittent fault.
ECM-0000 Impulse sensor. Signal too high, overspeeding.
ECM-0000 Impulse sensor: Signal faulty. Permanent fault.
ECM-0001 Secondary engine speed. Signal too high, over-revving
ECM-0001 Secondary speed. Signal faulty.
ECM-0001 Secondary speed. Signal too high, overspeeding.
ECM-0002 Fuel volume control valve. Faulty signal
ECM-0002 System relay output signal. Signal too low. Intermittent fault
ECM-0002 System relay output signal. Signal too low. Permanent fault
ECM-0003 Fuel volume control valve. Signal too low
ECM-0003 Needle lift sensor. Signal too high. Intermittent fault
ECM-0003 Needle lift sensor. Signal too high. Intermittent fault.
ECM-0003 Needle lift sensor. Signal too high. Permanent fault
ECM-0003 Needle lift sensor. Signal too high. Permanent fault.
ECM-0003 Needle lift sensor. Signal too low. Intermittent fault
ECM-0003 Needle lift sensor. Signal too low. Intermittent fault.
ECM-0003 Needle lift sensor. Signal too low. Permanent fault
ECM-0003 Needle lift sensor. Signal too low. Permanent fault.
ECM-0004 Accelerator pedal (AP) position sensor analogue signal. Power supply too high. Intermittent fault
ECM-0004 Accelerator pedal (AP) position sensor analogue signal. Power supply too high. Permanent fault
ECM-0004 Accelerator pedal (AP) position sensor analogue signal. Power supply too low. Intermittent fault
ECM-0004 Accelerator pedal (AP) position sensor analogue signal. Power supply too low. Permanent fault
ECM-0004 Accelerator pedal (AP) position sensor analogue signal. Signal too high. Intermittent fault
ECM-0004 Accelerator pedal (AP) position sensor analogue signal. Signal too high. Permanent fault
ECM-0004 Accelerator pedal (AP) position sensor analogue signal. Signal too low. Intermittent fault
ECM-0004 Accelerator pedal (AP) position sensor analogue signal. Signal too low. Permanent fault
ECM-0004 Accelerator pedal position sensor analogue signal. Power supply too high. Intermittent fault.
ECM-0004 Accelerator pedal position sensor analogue signal. Power supply too high. Permanent fault.
ECM-0004 Accelerator pedal position sensor analogue signal. Power supply too low. Intermittent fault.
ECM-0004 Accelerator pedal position sensor analogue signal. Power supply too low. Permanent fault.
ECM-0004 Accelerator pedal position sensor analogue signal. Signal too high. Intermittent fault.
ECM-0004 Accelerator pedal position sensor analogue signal. Signal too high. Permanent fault.
ECM-0004 Accelerator pedal position sensor analogue signal. Signal too low. Intermittent fault.
ECM-0004 Accelerator pedal position sensor analogue signal. Signal too low. Permanent fault.
ECM-0004 Fuel volume control valve. Signal too high
ECM-0005 Engine coolant temperature (ECT) sensor. Faulty signal. Intermittent fault
ECM-0005 Engine coolant temperature (ECT) sensor. Faulty signal. Permanent fault
ECM-0005 Engine coolant temperature (ECT) sensor. Signal too high. Intermittent fault
ECM-0005 Engine coolant temperature (ECT) sensor. Signal too high. Permanent fault
ECM-0005 Engine coolant temperature (ECT) sensor. Signal too low. Intermittent fault
ECM-0005 Engine coolant temperature (ECT) sensor. Signal too low. Permanent fault
ECM-0005 Engine temperature sensor. Signal faulty. Permanent fault.
ECM-0005 Engine temperature sensor. Signal too high. Intermittent fault.
ECM-0005 Engine temperature sensor. Signal too high. Permanent fault.
ECM-0006 Air temperature sensor. Signal too high. Intermittent fault.
ECM-0006 Air temperature sensor. Signal too high. Permanent fault.
ECM-0006 Air temperature sensor. Signal too low. Intermittent fault.
ECM-0006 Air temperature sensor. Signal too low. Permanent fault.
ECM-0008 Fuel temperature sensor. Signal too high. Intermittent fault.
ECM-0008 Fuel temperature sensor. Signal too high. Permanent fault.
ECM-0008 Fuel temperature sensor. Signal too low. Intermittent fault.
ECM-0008 Fuel temperature sensor. Signal too low. Permanent fault.
ECM-0009 Boost pressure sensor. Power supply too high. Permanent fault
ECM-0009 Boost pressure sensor. Power supply too low. Permanent fault
ECM-0009 Boost pressure sensor. Signal too low. Intermittent fault
ECM-0009 Boost pressure sensor. Signal too low. Permanent fault
ECM-0009 Charging pressure sensor. Power supply too high. Intermittent fault.
ECM-0009 Charging pressure sensor. Power supply too high. Permanent fault.
ECM-0009 Charging pressure sensor. Power supply too low. Intermittent fault.
ECM-0009 Charging pressure sensor. Power supply too low. Permanent fault.
ECM-0009 Charging pressure sensor. Signal faulty.
ECM-0009 Charging pressure sensor. Signal too high. Intermittent fault.
ECM-0009 Charging pressure sensor. Signal too high. Permanent fault.
ECM-0009 Charging pressure sensor. Signal too low. Intermittent fault.
ECM-0009 Charging pressure sensor. Signal too low. Permanent fault.
ECM-000A Atmospheric pressure signal of control unit. Internal fault. Intermittent fault.
ECM-000A Atmospheric pressure signal of control unit. Internal fault. Permanent fault.
ECM-000B Mass air flow (MAF) sensor. Power supply too high. Permanent fault
ECM-000B Mass air flow (MAF) sensor. Power supply too low. Permanent fault
ECM-000B Mass air flow (MAF) sensor. Signal too high. Permanent fault
ECM-000B Mass air flow (MAF) sensor. Signal too low. Permanent fault
ECM-000B Mass air flow sensor. Power supply too high. Intermittent fault.
ECM-000B Mass air flow sensor. Power supply too high. Permanent fault.
ECM-000B Mass air flow sensor. Power supply too low. Intermittent fault.
ECM-000B Mass air flow sensor. Power supply too low. Permanent fault.
ECM-000B Mass air flow sensor. Signal faulty. Intermittent fault.
ECM-000B Mass air flow sensor. Signal faulty. Permanent fault.
ECM-000B Mass air flow sensor. Signal too high. Intermittent fault.
ECM-000B Mass air flow sensor. Signal too high. Permanent fault.
ECM-000B Mass air flow sensor. Signal too low. Intermittent fault.
ECM-000B Mass air flow sensor. Signal too low. Permanent fault.
ECM-000D Reference voltage of control unit. Internal fault. Intermittent fault.
ECM-000D Reference voltage of control unit. Internal fault. Permanent fault.
ECM-000F Microprocessor of control unit. Internal fault. Intermittent fault.
ECM-000F Microprocessor of control unit. Internal fault. Permanent fault.
ECM-0011 Injection timing control. Injection too early
ECM-0011 Injection timing control. Injection too late
ECM-0012 A/C linear pressure sensor. Power supply too high. Intermittent fault.
ECM-0012 A/C linear pressure sensor. Power supply too high. Permanent fault.
ECM-0012 A/C linear pressure sensor. Power supply too low. Intermittent fault.
ECM-0012 A/C linear pressure sensor. Power supply too low. Permanent fault.
ECM-0012 A/C linear pressure sensor. Signal faulty. Intermittent fault.
ECM-0012 A/C linear pressure sensor. Signal faulty. Permanent fault.
ECM-0012 A/C linear pressure sensor. Signal too high. Intermittent fault.
ECM-0012 A/C linear pressure sensor. Signal too high. Permanent fault.
ECM-0012 A/C linear pressure sensor. Signal too low. Intermittent fault.
ECM-0012 A/C linear pressure sensor. Signal too low. Permanent fault.
ECM-0012 Air conditioning (A/C) linear pressure sensor. Faulty signal. Intermittent fault
ECM-0012 Air conditioning (A/C) linear pressure sensor. Faulty signal. Permanent fault
EFI-0011 Heated oxygen sensor (HO2S). Faulty signal
EFI-0011 Lambda probe. Signal faulty
EFI-0012 Volume air flow (VAF) sensor
EFI-0012 Volume air flow (VAF) sensor. Faulty signal
EFI-0013 Intake air temperature (IAT) sensor
EFI-0013 Intake air temperature (IAT) sensor. Faulty signal
EFI-0014 Throttle position (TP) sensor
EFI-0014 Throttle position (TP) sensor. Faulty signal
EFI-0014 Throttle position sensor. Signal faulty
EFI-0021 Engine coolant temperature (ECT) sensor
EFI-0021 Engine coolant temperature (ECT) sensor. Faulty signal
EFI-0021 Engine temperature sensor. Signal faulty
EFI-0022 Engine speed (RPM) sensor
EFI-0022 Impulse sensor. Signal missing
EFI-0025 Atmospheric pressure sensor
EFI-0025 Atmospheric pressure sensor. Faulty signal
EFI-0025 Atmospheric pressure sensor. Signal faulty
EFI-0036 Ignition adjustment signal. Faulty signal
EFI-0036 Ignition adjustment signal. Signal faulty
EFI-0041 Injection valve. Signal faulty
EFI-0041 Injector; Faulty signal
EFI-0044 Ignition coil
EFI-0044 Ignition coil. Faulty signal
EFI-0044 Ignition coil. Signal faulty
EFI-0056 Fuel pressure sensor (high pressure)
EFI-0056 Fuel pressure sensor (high pressure). Faulty signal
EFI-0056 Fuel pressure sensor (high pressure). Signal faulty
EFI-0058 Abnormal intake air. Faulty signal
EFI-0058 Intake air abnormal. Signal faulty
EFI-0066 Brake vacuum sensor
EFI-0066 Brake vacuum sensor. Faulty signal
EFI-0066 Brake vacuum sensor. Signal faulty
EFI-0089 Fuel system. Faulty fuel pressure
EFI-4008 Canister purge (CP) valve leakage. Intermittent fault
EFI-4008 Canister purge (CP) valve leakage. Permanent fault
EPS-0020 Pump motor. Signal too high
EPS-0021 Pump motor. Faulty signal
EPS-0022 Control module, internal fault
EPS-0030 Temperature sensor. Signal missing
EPS-0040 High temperature. Signal too high
EPS-0041 High temperature. Signal too high
EPS-0050 Memory fault in ROM. Internal fault
EPS-0051 Memory fault in ROM. Internal fault
EPS-0053 Memory fault in ROM. Internal fault
EPS-0060 Control module. Internal fault
EPS-0070 Power supply. Signal too high
EPS-0071 Power supply. Signal too low
EPS-0080 Steering wheel angle sensor. Faulty signal
EPS-0081 Speed. Faulty signal
EPS-0082 Engine status. Faulty signal
EPS-0083 Battery voltage. Faulty signal
EPS-E000 CAN communication. Faulty communication
EPS-E003 Configuration fault. Faulty configuration
GDM-0001 Speed signal. Faulty signal
GDM-0002 Headlamp range adjustment signal. Faulty signal
GDM-0003 Angle sensor. Faulty signal
GDM-0005 Control module. Signal too high
GDM-0006 Control module. Not calibrated
GDM-0007 Control module. Programming error
GDM-0008 Control module. Internal fault
GPS-0001 GPS antenna. Signal missing
GPS-0002 GPS antenna. Signal too high
GPS-0003 Control module. Internal fault
IAM-1001 AM/FM antenna. No signal
IAM-1002 AM/FM antenna. Faulty signal
IAM-2001 Control module. Internal fault
IAM-2002 Control module. Internal fault
IAM-2003 Control module. Internal fault
IAM-2004 Control module. Internal fault
IAM-2005 Control module. Internal fault
IAM-3001 Front left speaker. Signal too low
IAM-3002 Front left speaker. Signal too high
IAM-3003 Front left speaker. Faulty signal
IAM-3004 Front left speaker. No signal
IAM-3005 Front left speaker. Faulty signal
IAM-3011 Front right speaker. Signal too low
IAM-3012 Front right speaker. Signal too high
IAM-3013 Front right speaker. Faulty signal
IAM-3014 Front right speaker. No signal
IAM-3015 Front right speaker. Faulty signal
IAM-3021 Rear left speaker. Signal too low
IAM-3022 Rear left speaker. Signal too high
IAM-3023 Rear left speaker. Faulty signal
IAM-3024 Rear left speaker. No signal
IAM-3025 Rear left speaker. Faulty signal
IAM-3031 Rear right speaker. Signal too low
IAM-3032 Rear right speaker. Signal too high
IAM-3033 Rear right speaker. Faulty signal
IAM-3034 Rear right speaker. No signal
IAM-3035 Rear right speaker. Faulty signal
IAM-9001 Control module. Configuration fault
IAM-9002 Control module. Overheated
ICM-1A02 Control module. Faulty voltage
ICM-1A03 Control module. Faulty voltage
ICM-1A05 Control module. Faulty voltage
ICM-1A51 Communication with the audio module (AUD). Signal missing
ICM-1A52 Communication with the AM/FM tuner module (AFM). Signal missing
ICM-1A52 Communication with the antenna module (ATM). Signal missing
ICM-1A53 Communication with the multimedia module (MMM). Signal missing
ICM-1A54 C
En hoe ziet het lijstje van een NN er uit? ;D
Zo'n lange lijst, maar nog niet eens af (laatste foutcode staat niks anders dan een C)  ;D
Citaat van: elianmars op 11-01-2016 21:22:45
Vind je het weer niet genoeg? Zeikerd. ;D
maruska
chris had beter 1 post per code kunnen doen.. dan had mars het moeilijk gekregen met zijn 40000000 posts ;D
T-5R
Citaat van: Marc O. op 11-01-2016 21:06:52
Shut up  :P
Citaat van: Taranis op 11-01-2016 22:09:50
Shut up  :P
gelukkig kan er bij Marc ook nog eea aan de N kapot. Bij mij trouwens ook aan de XC60  8)
Citaat van: maruska op 11-01-2016 22:04:49
Hoeveel?  ;D
Chris
Citaat van: Taranis op 10-01-2016 22:29:02
Wat geeft Vida zelf voor uitleg voor de DDM-002C foutmelding?
Eindelijk even kunnen nakijken. Vida zegt dat de deze melding wordt opgeslagen als er sprake is van kortsluiting wanneer de spiegelverwaming is uitgeschakeld.
Binnenkort eens even loeren of ik kan ontdekking waar dan precies.
Chris
Maar weer eens even wat stof wegblazen hier.
Nog niet kunnen zoeken naar de kortsluiting van de spiegelverwarming aangezien we momenteel druk zijn met de verhuizing naar het tijdelijk huurhuis. We hebben ook een nieuw koophuis inmiddels, maar dat wordt pas per 1/6 opgeleverd. Niet erg dat we al een huurcontract hadden voor een half jaar vast aangezien we aan het huis ook nog wat willen verbouwen.
Met alle nattigheid van de afgelopen weken besloten afgelopen week maar weer eens te kijken hoe de deuren van de V eraan toe zijn op het gebied van roest. Ondanks de nieuwe rubbers, die overigens ook echt goed gemonteerd zijn, staat er in het rubber met het weer van de afgelopen weken zo'n beetje standaard een randje water in het deurrubber aan de bovenzijde. Ik zie bij beide achterdeuren toch alweer de nodige roestplekjes. Helaas heeft de bestuurdersdeur er ook in hele lichte mate last van. De 'gerepareerde' deur linksachter had ik bij het vervangen van de rubbers zowel onder het U-profiel als 'in het rubber' van fluid film voorzien. Je ziet dat het spul nog keurig aanwezig en vettig aanwezig is. Bij de andere deuren heb ik alleen preventief fluid film onder het U-profiel gespoten. Aangezien de deur rechtsachter en de bestuurdersdeur ook lichte plekken beginnen te krijgen als je het rubber omvouwt heb ik vandaag ook bij die deuren de roestplekjes onder het omgevouwen rubber in de fluid film gezet om in ieder geval het proces te remmen. Hopelijk werkt het voldoende. Komende tijd even goed in de gaten houden. Die deuren zijn nog dusdanig goed dat ze nog te redden zijn en ik anders een keer voor die deuren naar de schadehersteller ga om ze helemaal kaal te laten stralen en opnieuw te laten spuiten.
Het vervangen van de accu lijkt na enige tijd rijden geholpen te hebben. Ik heb geen rare afwijkende kilometerstanden meer gehad tot nu toe en ook geen meldingen in Vida :).
Verder bevalt de auto nog steeds erg goed. Hij rijdt heerlijk. Ik moet hem alleen nodig eens een keer wassen. Sinds ik hem heb, heb ik hem 1 keer heel goed onder handen genomen en daarna niet meer. Is niks voor mij, maar het is momenteel gewoon even te druk. Moet het wel weer een keer doen. Bij aanschaf had ik het hele schuif- kanteldak schoongemaakt, inclusief het rubber wat helemaal groen was. Rubber was nog goed en weer keurig schoon. Inmiddels begint zich alweer een groene aanslag te vormen, en dat terwijl de auto nooit onder de bomen staat ;D. Das toch wel een teken dat een keertje vaker wassen wel mag wat mij betreft ;).
Wat een gedoe zeg, die roest bij de deuren van zo'n N.
Succes met verhuizen, leuk vooruitzicht!
Chris
Citaat van: )()()sT op 08-02-2016 14:00:40
Ja, is idd gedoe. Maargoed, niet onoverkomelijk.
Tnx! Zeker lekker vooruitzicht. Echt onwijs zin in. Hopen op een goede zomer dan kunnen we lekker van de tuin genieten :D.
Is an sich ook niet verkeerd hoor, maar moet je wel een tuin hebben waar je een beetje in kunt zitten ;D ;D
Chris
#1828
Er heeft zich hier inmiddels toch wel aardig was stof verzameld, dus tijd om weer eens even stof weg te blazen :). Er valt ook zowaar weer eens wat te melden met betrekking tot de Volvo, niets spectaculairs, en daar ben ik ook wel blij mee, maar toch ;D.
De V70 moest vandaag voor de APK. Het was dus eigenlijk ook tijd voor de jaarlijkse beurt. Aangezien we momenteel flink aan het verbouwen zijn in onze nieuwe woning, en daar ook wel enigszins moet worden doorgewerkt, had ik er geen tijd voor om het beurtje zelf te doen. En eigenlijk had ik er stiekem ook helemaal geen zin in aangezien mijn leven momenteel bestaat uit werken, eten, klussen en slapen... en dat dan zo iedere dag door al enkele weken lang met in het weekend geen werk maar nog meer klussen ;).
Besloten de garage dus ook de beurt te laten doen. De 210k beurt stond op het programma. Ik vond de auto de laatste tijd koud slecht aanslaan, uiteindelijk deed hij het wel maar het ging soms wat moeizaam. Heb aangegeven dat ik graag wilde dat ze ook daarnaar zouden kijken. Zeker nu met de verbouwing moet de auto het gewoon doen, zonder morren. Het leek op onvoldoende brandstof direct na op contact zetten, want als je hem iets langer op contact liet staan en dan probeerde startte hij eigenlijk vrijwel direct en goed. De pomp was m'n gedachten al gepasseerd aangezien het erop lijkt dat het wel goed gaat als er wat druk is opgebouwd. Verder rook het na een koude start ook wat teveel naar benzine naar mijn mening.
De V vanmorgen vroeg neergezet. Ze waren snel aan de slag, want ik had ze al vrij snel aan de lijn dat het ze was opgevallen dat er toch wel een heel oud brandstoffilter onder zat. Aangezien ze niet terug konden vinden in de historie of die ooit vervangen was, was dat de eerste verdachte. Ook bougies konden ze niet terugvinden en zouden een deel van de oorzaak kunnen zijn, die wilde ik eigenlijk toch al een keer vervangen, dus opdracht gegeven zowel nieuwe bougies als een nieuw brandstoffilter te monteren. De V kwam verder glansrijk door de APK, geen bijzonderheden :). Ik ben dus weer tevreden en kan weer een jaartje roffelen.
Aangezien de auto niet echt had kunnen afkoelen morgen maar eens kijken hoe hij dan start na een nachtje gestaan te hebben. Vandaag lekker het goed, maar hij was dan ook nog wat warm. En dat leek altijd beter te gaan.... we zullen zien.
Nu eerst verder met verbouwen ;D! Begin dit jaar hebben we een nieuwe woning gekocht. Na 5 maanden op de sleutel te hebben gewacht was het op 1 juni zover: de sleuteloverdracht van onze grote mensen woning. Lekkere ruime tussenwoning met tuin op het zuiden en twee parkeerplaatsen op eigen terrein. De vorige bewoners waren helaas wel een stel beunen, dus ondanks dat het maar 5 jaar oud is zijn we flink aan het verbouwen. De badkamer was van slechte kwaliteit, zowel slechte kwaliteit materialen als erg slecht geplaatst. Voegwerk ontbrak of was slecht, zo ook kitranden waar nodig. De muren achter de tegels waren dan ook vochtig. De badkamer was dus de eerste op de nominatie om eruit te slopen.
De keuken die erin zat was ok, maar had zo weinig werkblad dat met Ireen haar gehobby in de keuken al snel duidelijk was dat we hier iets mee wilden. Eigenlijk wilde ik altijd al een barretje, dus zijn eens gaan oriƫnteren op de mogelijkheden. Omdat we ook geen halve beunoplossing wilden in een nieuw huis waar we hopelijk lang van gaan genieten viel hier uiteindelijk ook al vrij snel het besluit dat de keuken eruit zou gaan en er een hele nieuwe voor terug zou komen. Even een keuken verbouwen doe je ook niet zo makkelijk als je erin zit, dus voor zover het gaat willen we alles gedaan hebben om de komende jaren geen grote verbouwingen met sloopwerk te hebben.
Tot slot hadden de vorige eigenaren alle muren in het hele huis met structuur muurverf afgewerkt.... en helaas ook weer niet echt netjes. Grote verschillen in grofheid van de structuur en lelijk opgebracht. We laten de muren daarom netjes stucen en afwerken. Op al het hout zat alleen nog de grondverf uit de bouw, ook op de trappen, dus ik ben zelf maar aan de slag gegaan om alles te verven. Daarnaast nog genoeg klein grut aan klusjes natuurlijk. De tuin bewaren voor een later moment, die is opzich prima voor de komende tijd. We kunnen zitten, even wat onkruid wieden en grasmaaien en dan is het best voor nu. Vanaf augustus zitten we er binnen in ieder geval strak bij en kunnen we de komende jaren lekker vooruit.
Wat foto's van de mobiel, aangezien geen groothoek niet allemaal even biljant. Het gaat om het idee :).
Badkamer compleet eruit
En dat wordt het zoiets
Lekker huis, Chris!
En die twee parkeerplaatsen zijn ideaal! 8)
