cas
cas
NRE installed a 447 cubic inch Windsor engine with individual runner 8 throttle body efi - Making 630 hp and 590 ft lbs, this Mustang boasts throttle responce the likes of which we could only imagine. NRE fabricated a twin radiator system so the car could handle severe abuse without overheating and modified the fuel system for the efi, and  designed a billet torque converter to be used in conjunction with a sequential dog ring 6-speed transmission and incorporated an air operated transbrake to stall the input shaft to be able to use first and reverse gears when the engine is running.
zwamborn
Zundapp sprinter typ 448
Benelli BX 449
Mercedes 450 sel 6.9
zwamborn
Hoe die dingen in 1 minuut evolueren...  ;D
Citaat van: zwamborn op 13-06-2011 18:10:13
Time flies...............
Gouden Koets
michiel
ulkeman
international 453 simpel omdat de buurman die heeft ;D
afdeling dalfsen
irian paul
