Technische/Tuningsboards => Techniek Algemeen => Koppeling/versnellingsbak => Topic gestart door: konniekip op 01-12-2012 18:17:04
Titel: 'goedkope' ATF Dextron III-G bij volvo trucks.
Bericht door: konniekip op 01-12-2012 18:17:04
Net een verse kan 20L ATF Dextron III-G gehaald bij volvo trucks, bestelnummer is:  1161996.
Kost 141 incl BTW, kun je dus jaaaren mee vooruit of een aantal keer goed flushen
Dexron Type A, Suffix A Specification introduced in 1957. It requires the oil to meet certain limits regarding its kinematic viscosity.
Dexron IIDGeneral Motors Dexron®-IID Specification. ATF issued in 1975. Contained ATF cooler corrosion requirements not listed in Dexron® - II.
Dexron IIEGeneral Motors Specification Dexron®-IIE. ATF issued in 1991 requiring improved low temperature performance compared to Dexron®-IID, 20 000 cP at minus 40 °C.
Dexron IIIF
GM specification for Automatic transmission oil introduced in 1994. Successor of Dexron IID and IIE.
Dexron IIIG
Successor of Dexron III(F) automatic transmission fluid. This has the same low temperature characteristics as Dexron IIE, but with modifications to anti-oxidancy and friction material. Introduced in 1997.
Dexron IIIH
Dexron III licence H was introduced in June 2003 to replace the Dexron III G fluid. It has an oxidatively stable base oil (group 2 or group 3). Oils according to this specification have longer maintenance of friction properties and anti-shrudder properties, better foam control and a longer fluid life.
Dexron VI
Specification introduced in 2005 to replace Dexron IIIH. This specification requires better stay-in-grade properties, oxidative stability and anti-foam characteristics. Oils meeting this specification can be used with extended drain intervals and are energy conserving.
Titel: Re: 'goedkope' ATF Dextron III-G bij volvo trucks.
Bericht door: elianmars op 03-12-2012 00:51:59
Citaat van: konniekip op 01-12-2012 18:17:04
Dat laatste valt wel mee. Volgens mij heb je zo'n 14 liter nodig om te flushen.
Bericht door: RemkoT5 op 16-01-2018 19:01:14
Opgraving:
Mijn nieuwschierigheid weerhield mij niet omdat ik ook de automaat ook even flink ga doorspoelen een kannetje van 20,8L besteld bij Volvotrucks Nebim, helaas is de prijs niet meer die van 2012 maar voor 171,- incl btw ben je klaar en heb je ´originele :eusa_think:´ Volvo ATF Dexron III G.
Toch nog ´n 3 euro de liter goedkoper dan de MPM ATF III, die ik normaal gebruikte.
(http://i65.tinypic.com/2aajb4l.jpg)
Bericht door: arjenT5R op 16-01-2018 19:47:02
Eh... je moet die mannol dexron 6 nemen joh is veul goedkoper ;D
Geloof dat ik voor 150 euro 40 liter had...
Bericht door: -D©©©L- op 16-01-2018 20:08:05
Citaat van: RemkoT5 op 16-01-2018 19:01:14
Opgraving:
All Dexron-III licenses expired permanently at the end of 2006.
en dat betekent dat het ook niet meer te koop is of nog zal komen.  De enige geldige dexron specificatie is Dexron-VI.
In de praktijk kan je de zeker net zo goede JWS3309 olie voor minder kopen. (standaard in de 5AT mag in de 4AT).
Bericht door: RemkoT5 op 16-01-2018 22:49:33
Citaat van: -D©©©L- op 16-01-2018 20:08:05
Opgraving:
In de praktijk kan je de zeker net zo goede JWS3309 olie voor minder kopen. (standaard in de 5AT mag in de 4AT). Oke maar nu snap ik er even niets meer van, licentie is verlopen in 2006. Oke.
Dat het niet meer te koop is of nog tekoop zal komen. Oke. maar hoe komt dan n 20L vaatje in mn garage die ik vanmiddag heb gekocht en is afgevuld in aug. 2017
Citaat van: arjenT5R op 16-01-2018 19:47:02
Mooi, ga ik die de volgende keer halen, dank voor de tip. Spekkoper ben jij ook he ;D
Dat het niet meer te koop is of nog tekoop zal komen. Oke. maar hoe komt dan n 20L vaatje ATF III
in mn garage dat ik vanmiddag heb gekocht en is afgevuld in aug. 2017
Bericht door: -D©©©L- op 16-01-2018 23:00:01
Citaat van: RemkoT5 op 16-01-2018 22:49:33
Opgraving:
Dat het niet meer te koop is of nog tekoop zal komen. Oke. maar hoe komt dan n 20L vaatje in mn garage dat ik vanmiddag heb gekocht en is afgevuld in aug. 2017
Dat is geen dexron III-G
Bericht door: RemkoT5 op 16-01-2018 23:01:31
FQ me.  hebben ze me geen rooie reut verkocht dan?
Bericht door: UserID6342 op 16-01-2018 23:05:04
Zegt ook helemaal nul komma drie keer niks !  Is net zoals medicijnen, hun licentie (dus van Dexron) is afgelopen maar word nog steeds gewoon verkocht door onder andere hun zelf, maar ook door andere merken die aan die kwaliteitseisen moeten voldoen (is een heel ander iets). Eerst had Dexron het alleenrecht, sinds 2006 niet meer.  En natuurlijk is Dexron VI momenteel de huidige opvolger.  Backwards compatible.
Vergelijking van medicijnen is het volgende, zodra de licentie is afgelopen kunnen er goedkopere, vergelijkbare, medicijnen verstrekt worden van een ander merk.
Hoop onnodig geschreeuw weer hierover en weinig wol, nietszeggend.
En ja, Mannol is goedkoper, nog beter/goedkoper is Toyota ATF-T-IV. Is exact dezelfde olie voor de Aisin 4 bak.  Sterker nog voor de 4 bak volstaat zelfs Dexron ATF II-D !!
Bericht door: RemkoT5 op 16-01-2018 23:07:44
O. gelukkig maar, ik dacht dat ik weer eens in de vot was gepopt.
(http://i65.tinypic.com/2ekqedw.jpg)
Bericht door: RemkoT5 op 16-01-2018 23:09:02
Rooie reut is rooie reut, ik ga mn Aisin 4bak der mee spoelen. staat nu toch al klaar.
Bericht door: arjenT5R op 16-01-2018 23:26:46
Volvo zelfs!
Bericht door: V70R^2 op 16-01-2018 23:48:04
€115,-, 20 liter prima kwaliteit, motul "dexron III"
https://oeldepot24.de/motul-103993.html
of de ATF, bijna net zo duur en kan ook in de 5bak:
https://oeldepot24.de/motul-104001.html
Bericht door: UserID6342 op 17-01-2018 07:02:24
http://www.bandel-online.de/oele_/_schmiermittel/_20_liter_mannol_atf_type_t-iv_automatik_getriebeoel_fuer_toyota_etc_i64_100519_0.htm
Bericht door: RemkoT5 op 17-01-2018 08:25:55
So hey,  ;D dat is preis günstig einkaufen,
Bericht door: V70R^2 op 17-01-2018 11:35:36
Citaat van: Dirk342 op 17-01-2018 07:02:24
Deze heb ik ook gekocht destijds, om de brandstoftank drain & fill gedaan.
Vond het met de ATF erna wel iets smoother schakelen, leek minder slip te hebben.
Bericht door: spijky op 18-01-2018 21:09:36
Citaat van: V70R^2 op 17-01-2018 11:35:36
In welke bak? 4at of 5at
