Project "Auto van de vrouw" (oude Project Sharon thread)
Gestart door Barry_C70, 30-12-2006 20:55:59
Barry_C70
Is it possible to simply see whether the subframe isn't aligned properly or is that something that can only be measured?
de geneRaal
ben bang dattie toch te laag staat, of je zou wat smallere banden kunnen proberen van een forumlid ( inclusief velg natuurlijk  ;D )
groet maus
Blackstone under construction
BaRRaCuDa
Indeed, I think so too...
I'm afraid that if you want to keep riding at this height you'll be better of changing coilover  ::)
Citaat van: thuur op 10-05-2011 00:28:15
Citaat van: de geneRaal op 09-05-2011 23:33:49
hope i typed it right :P
Barry kan prima Nederlands lezen hoor, zoals hij zelf regelmatig aangeeft :D
Schrijven ook hoor.... Is ie alleen te lam voor  ;D
NinaPaul
doesnt really matter what language it is, aslong as you (can) understand eachother...
thats what communication is all about ;)
-Gottfried Leibniz
Barry_C70
Writing in Dutch takes much longer for me than writing in English and takes too much mind power to write these short messages.
I can't imagine that a different set of coilovers would work that much better that the KW's I have under the car right now. And what about the fact that its only the front right side that rubs and not the front left? I think if the wheel/tire combo was too big, then it would be rubbing on both sides and not just one I would imagine... right?
Citaat van: Barry_C70 op 10-05-2011 22:23:50
As English writing does for all the rest of us.
:D
Maar om op je opmerking terug te komen; het aanlopen kan natuurlijk ook gewoon zijn dat je kunststof binnenkuip links een halve centimeter naar buiten komt dan rechts, het is nu niet bepaald vormvast spul.
Barry_C70
Citaat van: Misha op 10-05-2011 22:26:12
:D
Hence why most post in Dutch knowing I'm able to read it just fine ;)
But yes, Saturday the car goes on the bridge, the wheels come off and I'm checking out the plastic well and seeing what I fix up under there. Getting tired of driving a badass Saffron coupe, lowered, 19" rims and oh, driving past people checking out the car and GGGGSSHHSGGGSSHSHSHHHHhh...
Barry_C70
Well, the car went on the bridge today and had the front wheels removed to see what was going on under there. Strangely, the front right KW coilover (which was the only side rubbing) was actually adjusted 2 notches higher than the left (which didn't rub at all). Strange that the higher adjusted side of the car was the side rubbing the most. Everything else was identical. So I raised the right side a further 2 notches, put the wheels back on and went for a drive. This sure enough improved the amount of rubbing experienced on bumpy roads but didn't fix it completely. After driving around with the adjusted height, I measured the distance from the top of the fender wheel arch to the ground and the right side was only 5mm higher than the left despite now being 4-5 notches higher than the left. How unbalanced are these cars??
I have also learnt that the tire was not rubbing against the outer fender wall, but against the rear upper edge of the well.
Barry_C70
#744
Just a lazy Saturday afternoon...
mooi hoor, als je de derde nog een keer neemt en dan precies tussen 2 kolommen zetten  ;)
fbm
Zeer mooie kar Barry! :eusa_clap:
Volvo Felipe
L1on
nice, very nice indeed...
