Group Buy - Metalic Teller Platen X70
Gestart door Barry_C70, 25-10-2007 04:10:17
Barry_C70
Feast your eyes on these:
this is a sample of anodized blue metalic gauges (same as in the new R's) but in X70  USA spec markings. This picture also shows all the markings LASER CUT from the faces so everything will be back lit and look stock at night but during the day, they will give off a really nice metalic blue look, unlike the other paper looking blue dials already available. or even our dull gray stock ones
click for full size:
The difference between the ones we'll get and this one in the photo are that the markings will be Euro spec, so that means the fuel gauge will read in liters, the UNLEADED FUEL ONLY :P will be gone and the speedo will read in kmh up to 260kmh (obviously these US spec dials would be inaccurate on our cars)
You have options as well! (yes choice is good no?) Thuur and I have talked some about creating a custom solution to create a FRONT LIT solution for the gauge cluster just like in the new Rs. We have yet to experiment but are confident we can pull this off with installing LED lights at the top of the cluster. Just like Thuur's ABS module fix, we hope that this solution will appeal to others if they want it installed in their cars maybe by ordering a kit or sending the cluster to him. So what does this mean?
This means that the dials will also be available with the numbers laser ETCHED into the metal so they won't be back lit and will be white/aluminum looking, however the increment markings around the speedo and rpm faces will remain cut and back lit. Now I know not everyone wants the R look, especially on this forum ;) So there are also other colors available for those more conservative:
As well as Anodized Blue (pictured) there's Brushed/Untouched Aluminum, and MAYBE Polished Black or Gray
The other options are either ALL markings (so increments, numbers, fuel and oil icons and X1000R/min) laser cut and back lit (like in the picture) OR
ONLY the increments are laser cut and the rest are laser etched, depending on what people think, maybe everything can be etched too.
PRICE is 55 Euro a set. Not sure how much Thuur will ask for his front light solution, that will be determined when we figure how we're going to pull that off, or you can do it yourselves!
Anywho there you go, lets see what you think, put your name and the color/s you'd want (blue, aluminum, black/gray) next to your name,
Everything laser cut and backlit
Increments laser cut and backlit and everything else laser etched
- Barry_C70 (blue)
Everything laser etched-
EDIT: For those who don't get what I just wrote:
ok, nou dan
je kunt ze in blauw, aluminium en mischien metalic zwart of grijs, dat zijn de kleur opties
EVERYTHING LASER CUT houd in dat het precies hetzelvde uit zal zien als de tellers die jij nu hebt, het licht zal door de beletering en nummers and lijntjes door schijnen, dat is wat de foto laat zien.
HALF LASER CUT AND ETCHED houd in dat the lijntjes aan de rand van de snelheid en toeren tellers net zo zijn als boven, the licht schijnt doorheen net zo als de tellers die julie nu hebben. the rest word ge-etched? dat betekent dat het net alsof het erop gedrukt/geprint is, en het zal wit zijn, maar daar komt natuurijk geen licht doorheen, dus moet je verlichting voor de tellers of zelf maken of je wacht af wat Thuur en ik maken. het resultaat zal net zijn als in the nieuwe R autos, dus zo:
MarcoV
#1
- Barry_C70 (blue)
- MarcoV      (blue)
Barry_C70
bump for those who don't check this area of the forum too often...
Dave
Ik heb ook interesse in zo'n setje tellerplaaten, in't blauw zoals hierboven. Ik vroeg me enkel af wat ik me mag voorstellen bij de optie die Barry hier naar voor schuift. Het klinkt wel mooi, maar zie je dan nog wel cijfers op de tellers bij nacht?
Barry_C70
If you go for the etched numbers, then they will NOT be backlit like your current dials and you won't be able to see them at night, you'll have to implement some kind of front lit solution, so maybe see what Thuur and I come up with later OR you can try your own solution like drilling holes at the top of the cluster and installing LEDs or something to light the front of the faces.
The option to have everything laser cut will have everything backlit and thus visible at night without further modification
I plan on ordering both ;)
jberg
in combinatie met alu tellerringen is dit wel tof, ik kan me alleen nog niet zoveel voorstellen bij die combi etched/backlit, heb je een foto van deze? mischien van een v70r n
daytonawim
IK kan me er ook niets bij voorstellen (helaas) zoek eigenlijk die van de S70R
Robert Haven
van deze technisch uitleg kan ik geen hout snijden....
wellicht maken foto's by night de zaak wat duidelijker? En dan vooral de verschillen tussen de opties... ???
Citaat van: Robert V70 NBP op 25-10-2007 19:33:33
Of eens proberen in het Nederlands? Je kan het!
Robert Haven
Citaat van: Emiel op 25-10-2007 19:37:57
net zo onduidelijk als de tekst van barry
Citaat van: Robert V70 NBP op 25-10-2007 19:39:03
Simpel... :P
Als Barry het in het Nederlands hier neerzet zal je het wel snappen...
Robert Haven
Citaat van: Emiel op 25-10-2007 19:41:43
[Als Barry het in het Nederlands hier neerzet zal je het wel snappen...
zeker  :eusa_wall:
Barry_C70
ok, nou dan
