centrale speaker in dash
Gestart door Mik, 10-02-2004 14:01:57
Mik
Ik ben voornemens om een het bovenste gedeelte van het dashboard te vervangen, door een dash met centrale speaker. Wat ik wil weten is of het vervolgens moelijk is die speaker aan te sluiten op het audiosysteem.
Overigens ben ik ook benieuwd of iemand een indicatie voor de kosten kan geven.
Mike
haya
Hier is wat meer info over centrale speakers (http://www.mobileaudio.com/rac-faq/). Ziet ernaar uit dat je ook een signal processor nodig hebt.
"If a proper center image isn't achievable via a two channel configuration, installation of a center channel can help. Since the majority of recordings are done in two channel, a two channel system designed correctly should be able to reproduce a center image which was captured during recording. A center channel is not simply a summation of the left and right channels, like bridging an amplifier; rather, it is an extraction of common signals from the left and right channels. This usually means the lead vocals, and perhaps one or two instruments. These signals will then be localized to the center of the stage, instead of perhaps drifting between the left center and right center of the stage. A signal processor is usually required in order to properly create a center channel image. The image should then be sent to a driver in the physical center of the front of the car, at an amplification level somewhat lower than the rest of the speakers. The correct frequency range and power levels will depend on the particular installation, though a good starting point is perhaps a pass band of 250-3000Hz at an amplification level of half the power of the main speakers (3dB down). "
Haya
