Olie speciaal ontwikkeld voor Volvo's
Gestart door Entuscan, 19-08-2005 23:36:12
Entuscan
Iemand deze olie al getest:
Ik zag hem in de week bij de dealer ...
Citeer
Exhibitor's platform
Index    « 12/27 »
27-02-2005
Developed with and for Volvo
Castrol SLX R-Tec
New from Castrol
Castrol is the leading producer worldwide of lubricants and together with the automobile manufacturer Volvo has developed a special fuel-saving light motor oil that has been specially prepared for the newest generation of Volvo motors: Castrol SLX R-Tec – the best for Volvo motors.
The new Castrol SLX R-Tec is particularly suitable for fulfilling the requirements of modern petrol and diesel Volvo motors. Extensive research work on the part of both companies was invested in this new special product to reach the common goal of economical, environment-friendly and high-performance vehicles for personal transportation. The new Castrol SLX R-Tec, which was exclusively produced for Volvo, guarantees complete and safe lubrication even with very long periods between oil changes as well as economical and ecological mobility that takes natural resources into account.
A further advantage of the new Castrol R-Tec for Volvo is the wide range of applications, which reaches from the demanding fuel-injection diesel models to the high-performance petrol motors of Volvo.
A special motor oil for Volvo – because only the best is sure enough.
ACEA A5/B5 – superior to A1/B1
SAE OW-30
API SL
Volvo WSS-M2C913-B
Properties:
•Tested and approved by Volvo for the newest generation of motors
•Low viscosity at high temperatures for constant fuel saving with long periods between oil changes
•Excellent performance at all temperatures
•Splendid resistance to oxidation for guaranteed protection against wear
•Wide application for Volvo motors from 2004 with ACEA A5/B5 or A1/B1
•Specially developed with and for Volvo
Volvo recommends Castrol
Toch mooi dat zoiets nu bestaat, alhoewel op het eerste zicht wel enkel voor de nieuwe modellen
http://castrolproductlaunch.net/
Reitse
Wat is er zo speciaal aan een Volvo-blok dat er een aparte olie voor ontwikkeld moet worden?  Zijn gewoon 5 zuigers in cylinders die hard op en neer gaan doordat er wat benzine in de fik gestoken wordt.
Ergens staat me bij dat Castrol en Ford heel intiem waren, en Volvo was altijd met Shell heel innig...
Citaat van: Reitse op 20-08-2005 00:21:41
Ik denk dat ze een beetje een temperatuur probleem hebben bij de R modellen..  ;D
Voor de R raden ze trouwens 5W-40 aan en niet die 0W-30.
R staat ook op 20d km service en de andere modellen op 30d km.
wizard
Dan is die tijd geweest want zelf op de olievuldop staat castrol.
Had even een nieuwe gehaald vandaar.
don't hate the player, hate the game
denkweb
Mijn dealer dondert er nog steeds Shell in... ?
